YouTube - Ford 2.3L clicking noise
Greetings Stangneters, I'm just done "rebuilding" a II for my daughter. I've got the block borred 30 over, installed new bearings/rings/ polished the crank.
I reinstalled the old heads becaused they looked "good enought" but I had that clicking sound
So I bought a new head complete from Marshall engines ... and I still have that dam clacketing sound
Local mech said it was normal, all those 2.3 Ford do that. I don't believe it, so I'm refering the ones that know
It seems to be coming from cylinder #1 area. Would it be a problem with my lifter? ... but I have that with both old and new heads. Would it be a clogged oil galley leading to my #1 lifter?
Anyway, what the heck is it and how do I fix it?
Side info:
Initial timing is set @ 14BTDC, manual says 10, but I'm at high alt.
When I stick a vacuum gauge on the front of the intake manifold, the tunel leading to #1 cylinder I have 15" initially, needle is barely flutuating 1/2 inch. After the initial start up vac gradually goes down to 13" and stays there @ 1,000 rpm, warm engine. Maybe a slightly clogged cat? Pressure at the muffler seems pretty strong.
Now I live in Salt Lake, 4,200 feet high. When I gently accelerate engine tops at 17", jumps to 20 when I let go. On a fast rev, gauge goes down to 4". All that sounds normal.
Build vid:
YouTube - Summer's car "rebuild".
Thx for taking the time to read/watch, cheers!
It seems to be coming from cylinder #1 area. Would it be a problem with my lifter? ... but I have that with both old and new heads. Would it be a clogged oil galley leading to my #1 lifter?Anyway, what the heck is it and how do I fix it?
Side info:
Build vid:
