Hi From Canton, Ohio
  • Thread starter Thread starter slowride1959
  • Start date Start date Sep 8, 2013
slowride1959
  • Sep 8, 2013
Im new to the Mustang world (ownership that is) i have a question and many more prob. But i have purchased an 83 HB that originally had a 4 cyl. In it and someone converted it to a 302 V8. The question i have is someone previous stripped out the threads in the bottom hole for the starter and lm looking to be going to a swap meet next weekend and go in search of another bellhousing with good starter mounting threads. I have done a little research in this and is there a way to find out what bellhousing i need without pulling the trans and get the part number off of the bellhousing thats on it? Or is it a guessing game if i dont pull it? I appreciate any and all input i get from all you fine folks on it. Thanks, and have a great one!!
slowride1959
  • Sep 8, 2013
slowride1959
  • Sep 8, 2013
Sorry, left out that its a c4 trans from 1983 Thanks Again
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 8, 2013
  • Sep 8, 2013
You can helicoil the bolt hole in the bellhousing instead of getting a replacement bellhousing. Run a tap through the hole the same size as the helicoil and then screw it in. Problem solved.
NTO_GUY
5 Year Member
Indiana
Sep 9, 2013
  • Sep 9, 2013
I agree. Helicoil is about a 10 min fix in most cases.
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Fox 4 Cyl to V8 Swap Info Thread
  • Matt01
  • Jul 12, 2021
14K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 9, 2023
Robinson
R
Engine Engine and Transmission Removal Tips
  • Justin87
  • Apr 5, 2019
2K
Fox 5.0 Mustang Tech Apr 27, 2019
Justin87
