Yes, I searched this. I just need help from people that have done this before.
The only problem I'm running into is running the main harness back to the passanger side. Did you guys go over or under the radiator?
Right now I'm doing it under and it looks like I'll have to extend the pass. side headlight and corner light. (Most people just extend the pass. head light).
I know Eades didn't extend any wires. Care to chime in Chris?
Thanks, I appreciate the help!
Jake
Jake
. I zip-tied the wires to the steel bumper. I don't know if that will work with the stock overflow bottle and pcm location because I relocated both of them. The only wires I extended were for the spout connector since I couldn't get to it with smoothed fenders, and also the alternator since I moved the fuse box inside the fenderwell.
) in the stock location. If you look at the very bottom right of this pic you can kinda see the wire.
