  • 1994 - 1995 Specific Tech
Hiding wires??
  • Thread starter Thread starter h0oligan
  • Start date Start date Sep 18, 2004
  • 3
  • 4
First Prev 2 of 4 Next Last
Dave95GT
bAd mUtha
477
Looking for all of my missing posts
Sep 20, 2004
#21
  • Sep 20, 2004
  • #21
h0oligan said:
Very nice and clean. Makes the engine bay look so much more wrench friendly, especially with that battery out of there. Did you have to extend any of the wires to reach or will they all reach with the proper re-routing. And where in front of the radiator, up top or lower? Or could I just put mine underneath the stock black radiator cover.
The harness runs in front of the radiator on the bottom of the radiator support. Ill try to get more pictures tomorrow. As far as extending wires, only the pass side headlight, corner light and fan wires had to be extended, everything else fit. For the overflow, I bought a 10" stainless resivoir and mounted it between the radiator and frame on the drivers side. I did take the power steering out but all that required was mounting the coil in a different place and running a shorter belt with a stock waterpump pulley. Like I said, Ill get some more pictures in the morning, I lost about 6 months worth of pictures that included all the under construction pics showing how all the wires were run and all that.
donjohn
1,757
Irvine - Southern California
Sep 20, 2004
#22
  • Sep 20, 2004
  • #22
what do you mean that's all it required to take out the ps? like, did you get a bigger gear or a manual steering rack or something? could you expand a little on this- thanks? just looks so clean and good
also, a bunch of guys just took off the black cover that goes over the headlights back to right over the radiator and ends before the reservoir. is it just taken out for the pics or is there really no point to it and it can be removed? just looks like a cosmetic cover to me
Dave95GT
bAd mUtha
477
Sep 20, 2004
#23
  • Sep 20, 2004
  • #23
I still have the factory PS rack, but no pump. The lines and PS cooler are gone as well. Finding the right belt size was tricky because I had overdrive pullies. I went thru about 10 belt sizes and swapping pullies until I found a combo that worked.
That cover is just cosmetic, it covers up some AC lines and the hose that goes from the radiator to the overflow bottle.
donjohn
1,757
Sep 20, 2004
#24
  • Sep 20, 2004
  • #24
o k, so is steering like really difficult for you... mine's a dd (daily driver) but i would like to do that if it doesn't affect too much
and it looks like the oil air breather line goes to the fox tb?
D
DARK-5.0
724
Leawood, KS
Sep 20, 2004
#25
  • Sep 20, 2004
  • #25
Hiding the wires and smoothing out the fenders was one of the most time consuming jobs I've done yet. I think I have more hours into those fiberglass inner fenders than puttin the motor together. Go figure.
Jeremy
D
DARK-5.0
724
Leawood, KS
Sep 20, 2004
#26
  • Sep 20, 2004
  • #26
p.s.
the entire main harness is hooked up in that photo. just not the fuel system harness.
Jeremy
donjohn
1,757
Sep 20, 2004
#27
  • Sep 20, 2004
  • #27
wow, i'd like a little better quality pic but from here it looks pretty damn cool
D
DARK-5.0
724
Leawood, KS
Sep 20, 2004
#28
  • Sep 20, 2004
  • #28
Thats the best I have for right now. I'll have the motor back together for the 3rd time in a month on tuesday, So i'll snap some new pics then, but I do have these.
Jeremy
donjohn
1,757
Sep 20, 2004
#29
  • Sep 20, 2004
  • #29
jeez, nice molding and paint job ... arc, mig, tig?
D
DARK-5.0
724
Leawood, KS
Sep 20, 2004
#30
  • Sep 20, 2004
  • #30
that fiberglass my friend, and the first time i had ever worked with it i might ad. up close you can see the imperfection but when i redo the block this winter, i'm gonna go back and use sheetmetal like zach is doing right now. I had seen the sheetmetal done before and wanted to try something different.
Jeremy
donjohn
1,757
Sep 20, 2004
#31
  • Sep 20, 2004
  • #31
oops, i forgot u could use it that way, i was thinkin sheet metal like zach (1105)
D
DARK-5.0
724
Leawood, KS
Sep 20, 2004
#32
  • Sep 20, 2004
  • #32
its all good man
Jeremy
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Sep 20, 2004
#33
  • Sep 20, 2004
  • #33
Why did you go with fiberglass in the first place? I would think that'd require a lot of prep work before it was smooth. Looks nice though. Whenever you go to do the sheet metal, just be careful when welding it in. Turn the welder down low, and just put a tach every inch or so all the way around, then go back and put a tach inbetween the ones you allready did and do on until its all welded up. You wont be able to weld normal since the sheet metal and the metal used for the fenders is so thin.
Dave95GT
bAd mUtha
477
Sep 20, 2004
#34
  • Sep 20, 2004
  • #34
Yeah it takes a little more effort to turn the car at low speeds, but if youre going more than 10mph, its no big deal at all. Sometimes parking in a confined space can suck, but I just think of it as my way of not having to go to the gym
And yeah, the oil breather tube goes from the oil filler tube to the Fox tb.
D
DARK-5.0
724
Leawood, KS
Sep 20, 2004
#35
  • Sep 20, 2004
  • #35
I just wanted to do something different. I went out trying it to see if it worked. I knew the sheetmetal worked, but I didn't know about fiberglass. I kinda figured that I would have to put it on low, but thanks for the knowledge. I need all of it I can get.
Jeremy
donjohn
1,757
Sep 20, 2004
#36
  • Sep 20, 2004
  • #36
yea, thanks for the info 1105 and dark-5.0
1105
May 3, 2003
3,841
Daytona Bch, FL
Sep 20, 2004
#37
  • Sep 20, 2004
  • #37
no prob. I'm going back out to work on my car now. Hope to get the drivers side fender all done today. Pictures in my thread later tonight.
Dave95GT
bAd mUtha
477
Sep 20, 2004
#38
  • Sep 20, 2004
  • #38
Here are a few more pictures...
The stainless overflow bottle mounted to the radiator
The harness in front of the radiator (kinda hard to see)
D
DARK-5.0
724
Leawood, KS
Sep 20, 2004
#39
  • Sep 20, 2004
  • #39
Thats how I ran mine too Dave. Actually, ours is ran the same because I copied all of your steps and pictures. Only, since i have the fenders molded, I'm using the bottom plate where the air box use to be like a shelf and thats where my ccrm is.
Jeremy
Dave95GT
bAd mUtha
477
Sep 20, 2004
#40
  • Sep 20, 2004
  • #40
Jeremy
You dont have any of my old pictures saved do you? I lost about 6 months of pictures, including the wire hiding pics.
  • 3
  • 4
M
Kind of a unique problem
  • MadMatt7
  • Oct 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 15, 2026
rednotch
G
Hello and Instrument Wiring
  • GT Jon
  • Jul 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 6, 2026
Mustang5L5
J
89 mustang alarm install to lock and unlock
  • jk66
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2026
jk66
J
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
Resolved 83 alternator wiring harness
  • sparten5000
  • Aug 2, 2026
Fox 5.0 Mustang Tech Aug 23, 2026
limp
