High Torque Mini Install Have a ?
  • Thread starter Thread starter ram360
  • Start date Start date Jun 4, 2006
ram360
2,162
Pennsylvania
Jun 4, 2006
  • Jun 4, 2006
Read a few posts of things being wired wrong with the hight torque mini and don'tfeel like frying the starter or blowing up my battery. Just want to doulbe check on the wiring for it before I go installing it. It has 2 terminals (one small and one large) SO what goes where? What gauge wire should I run to the smaller terminal and where do I connect it?
ram360
2,162
Pennsylvania
Jun 4, 2006
  • Jun 4, 2006
searched but can't find a how to for it
ram360
2,162
Pennsylvania
Jun 4, 2006
  • Jun 4, 2006
Nevermind:
Found this:
You have to move the large wire that goes to the starter from the "starter motor" side of the fender mounted solenoid to the "battery" side of the solenoid. Then run a 12ga wire from the small ternimal on the starter motor to where you moved the large wire off the starter solenoid - on the "starter motor" side.
old_blue
1,783
282
124
Jun 4, 2006
  • Jun 4, 2006
thats confusing as all hell. good luck with it
89Notch
1,669
MSU
Jun 4, 2006
  • Jun 4, 2006
ram360 said:
Nevermind:
Found this:
Basically, a selenoid is a relay, there are 2 big terminals and 1 small terminal. One big terminal has power all the time, and the other big terminal only receives power when the small terminal receives power.
The new starter contains its only relay so the larger terminal needs power all the time (aka connect it to the hot side of the selenoid) and the small terminal tells the starter to draw from that larger wire. All you have to do is hook up the small relay wire to the wire that comes from the ignition that says you are starting. I use a 2ga wire for the larger wire and 14ga maybe for the relay wire, it doesn't draw much power.
If you connect the starter motor relay wire to the side specified in your quote then you might get lagging, where the fender mounted selenoid has to shut off then the starter motor has to shut off so when you put the key in the on position from the start position the starter will still turn over for a little bit. I had this problem so I rewired how I stated above and now it is geat.
Hope this helps...
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jun 4, 2006
  • Jun 4, 2006
i didn't install the jumper when i first installed that starter. the starter wouldn't start. i was told you didn't have to install it. the guy was an idiot. I installed the little wire and been running ever since. Car kinda sounds like a diesel starter when its cranking.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 4, 2006
  • Jun 4, 2006
If you can read electrical diagrams, this will get you exactly what you need.
For future reference...
AutoZone wiring diagrams
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model Mustangs
ram360
2,162
Pennsylvania
Jun 4, 2006
  • Jun 4, 2006
Good info guys... I'll see if I can get it to work.
ram360
2,162
Pennsylvania
Jun 13, 2006
  • Jun 13, 2006
Wired it up today. Works nicely, thanks for the help guys.
P
postalbunny
118
Oct 8, 2006
#10
  • Oct 8, 2006
  • #10
I know thread is old... but why can't you just install the starter the same as a normal one, but with a jumper across the mini's solenoid?
rd
3,316
63
109
Ocean Springs MS
Oct 8, 2006
#11
  • Oct 8, 2006
  • #11
The Ford Racing website has the directions including the wiring instructions for the FRPP mini starters.
Saleen0679
876
24
49
Yakima, WA
Oct 8, 2006
#12
  • Oct 8, 2006
  • #12
Per Ford's instructions:
"! ! ! WARNING: DO NOT INSTALL A JUMPER WIRE BETWEEN THE BATTERY TERMINAL AND THE SOLENOID BLADE TERMINAL AT THE STARTER TO AVOID THE USE OF THE # 12 WIRE. IF DONE, VOLTAGE IS GENERATED TO THE SOLENOID BY THE STARTER SPINNING AFTER THE RELEASE OF THE START KEY OR BUTTON, CAUSING THE STARTER TO REMAIN ENGAGED, RESULTING IN SEVERE DAMAGE AND EVENTUAL FAILURE OF THE STARTER ! ! !"
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Oct 8, 2006
#13
  • Oct 8, 2006
  • #13
Well said saleen0679! I know i was thinking it either sounded desielish or sorta moparish? Either way it does sound diffrent. peace
john
P
postalbunny
118
Oct 9, 2006
#14
  • Oct 9, 2006
  • #14
Wow... i guess if it was spinning it could generate voltage like the alternator.
How 'bout this, i noticed the solenoid (on the mini) has 2 big terminals (one for the constant + and one that goes into the starter), can I run the + wire directly to the one that feeds the starter and bypass the 12g and constant + altogether.
Just don't want to run another wire, and my fender solenoid is already FULL, i can't get anythign else on the const + side of it... already have audio amp + fog lights on the battery post itself... and i ordered a elec fan
P
postalbunny
118
Oct 9, 2006
#15
  • Oct 9, 2006
  • #15
Hell, it would be nice if I could take the solenoid off the starter completely.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
Engine Carb swapped 89 starting issue
  • cbac89
  • Sep 14, 2024
Fox 5.0 Mustang Tech Sep 14, 2024
General karthief
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
