High Torque Starters
  • Thread starter Thread starter d.r.moss
  • Start date Start date May 7, 2009
d.r.moss
54
Rochester, MI
May 7, 2009
  • May 7, 2009
I have an 88 5.0. The starter is shot, I believe from the heat. I have done alot of research and found I can use a starter out of a newer 5.0. I bought a 95 starter with a lifetime warranty today, and want to install it this weekend. I am aware of the rewiring that needs to be done and I got that covered. My consern is the original starter's gear was center on the end were the newer starter is offset. Also I believe the original gear was 9 tooth were as the new one is 10 tooth. I do not want to eat up my flywheel and I am going to beat up the starter getting it past my headers, so I just want to be sure this will fit. To solve the heat issue I am going to wrap it with a heat blanket or something. Has anybody used a 95 starter on an older model? Will this work? Anything else I need to be aware of?
warriorpluto
267
monroe.LA
May 7, 2009
  • May 7, 2009
i just went with a 93 mustang mini starter.
d.r.moss
54
Rochester, MI
May 7, 2009
  • May 7, 2009
the 93 and 95 are the same starter arnt they
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
May 7, 2009
  • May 7, 2009
Not 100% sure about the tooth count on a '95, but the mini-starter on a '93 5.0 can be retrofitted on any T-5 or AOD all the way back to at least '83. I'm running a starter off a '90 Crown Victoria on my '84 AOD 5.0 hatch.
The wiring is about as easy as it gets. Move the fat cable off the switchable side of your fender solenoid to the battery side, then run a wire from the switchable side (where the fat cable once was connected) down to the small post on the mini-starter with a ring connector on each end of the wire. Done.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
May 8, 2009
  • May 8, 2009
I think the Mini Starters were the same from 92 through 95.
87WhiteStang1
182
  • May 8, 2009
for the wire you run from the switchable side of soleniod to mini starter, What gauge wire should i use?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 8, 2009
  • May 8, 2009
Starter solenoid wiring for 86-91 Mustang
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
d.r.moss
54
Rochester, MI
May 8, 2009
  • May 8, 2009
I just picked up 12 gauge wire just like the diagram shows. Going to put it all together this weekend. I actually traded a lifetime warrenty 88 starter for the high torque at the auto parts store, a $50 difference. So my conversion is going to cost $8, the cost of the wire
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
R
Flex plate and starter issues
  • RJH46
  • Jun 24, 2025
  • Other Auto Tech
2K
Other Auto Tech Aug 19, 2025
nickyb
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
