I have a high mileage 5.0, probably close to 200,000 miles, but still runs strong. It just had the oil pump seize, and I replaced it with the high-volume pump, as I figured the motor is loose enough to handle the extra flow without high pressure issues.
PSI Numbers:
30 - 35 cold
50-55 at speed cold
45-50 at speed warm
25-30 idle warm
I hear from many about staying away from the high volume pumps. Is it more of an issue for new tight motors that cannot handle the increased flow?
BTW, as soon as the pressure dropped, I turned off the motor. No new noises since replacing the pump & shaft.
PSI Numbers:
30 - 35 cold
50-55 at speed cold
45-50 at speed warm
25-30 idle warm
