  • SN95 4.6L Mustang Tech
Highest aspect ratio I can run?
  • Thread starter Thread starter Jbauer
  • Start date Start date Feb 16, 2008
J
Jbauer
506
  • Feb 16, 2008
i lowered the GT with the pro kit a few days ago, but the rear aren't as low as i would like them. It is my understanding that even if I go to 18s, i can actually have MORE wheel gap if the aspect ratio is smaller..so i figured, i can run my stock 17s with a higher aspect ratio, and the gap will be smaller, right?
Right now i've got 245 45 17, Is it possible to go to say.. 55 for the A.S?
Don't know much about wheels..so please forgive me if i come off like a dumbass
N
Nightstick
68
  • Feb 16, 2008
Best thing you can do is go here http://www.tirerack.com/tires/Spec....&vehicleSearch=false&fromCompare1=yes&place=6
and look at tire specs and see how much effect the ratio has on the OD of the tire. A wider tire of the same aspect ratio will be taller and lessen the fender gap.
I chose not to lower my car but wanted to do the same so I just went up to 255/45/17 on the stock rims. Its wider but its also 4/10s of a inch taller and made it look noticably better.
J
Jbauer
506
  • Feb 17, 2008
So what if i went to say..300/35/18.. would the gap look smaller or larger?
isjoining
143
Orlando, FL
Feb 17, 2008
  • Feb 17, 2008
gap would look smaller, but your speedometer would be 2.2% off.
J
Jbauer
506
  • Feb 17, 2008
But isn't 35% of 300 Smaller than 45 percent of 275? If aspect ratio affects the height of the tire; wouldnt i have MORE wheel gaps with the 18s?
isjoining
143
Orlando, FL
Feb 17, 2008
  • Feb 17, 2008
you never said anything about 275/45 tire size, so i was comparing it to 245/45/17. 300/35/18 will have a bigger overall diameter than 245/45/17 and therefore the gap would be smaller.
J
Jbauer
506
  • Feb 17, 2008
sory, typo- it IS A 245 45 17
J
jprovence
195
Albany, OR
Feb 17, 2008
  • Feb 17, 2008
Are the springs brand new, if so, they have to take a few weeks to settle.
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,118
224
Massachusetts
Feb 17, 2008
  • Feb 17, 2008
Give the springs time to settle.
If you start playing with wheel sizes, it also throws off the ABS system and will cause an error.
Stock tire diameter with 245/45/17 is 25.7". You need to stick close to this number.
Good tire calc to use
http://www.miata.net/garage/tirecalc.html
J
Switched to e85 on the 3v and now it won't run right.
  • jcowdough
  • Aug 24, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 24, 2025
HP woes with Sniper Sytem
  • Stang_1973
  • Mar 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
