Hmmm...Help Needed
  • Thread starter Thread starter 1988WHTGT
  • Start date Start date Apr 20, 2006
1988WHTGT
270
Guyton, GA
Apr 20, 2006
  • Apr 20, 2006
Ok, when I raise my hood after driving or if the car is somewhat warm, I smell coolant. Nothing is leaking anywhere, I've checked everything. The rebuild on everything is a year old. What could be the problem? Also, I let it sit for about 3 weeks or so over xmas and when I got back there was a little coolant on the ground that I saw was dripping off of the balancer. But with normal use it doesn't leak anything. Any ideas?
LX302
Stanger
728
Bethlehem PA
Apr 21, 2006
  • Apr 21, 2006
Yes, you have a leak.
It's just with the car warming up the coolant is being evaporated, so you don't see it, but smell it.
If it's on the balancer area, I would say it's your waterpump.
Start the car, and run it till you get it up to operating temperature and look at the waterpump. There is a small hole under the casting. I susupect it is leaking from there. It means your waterpump bearing is shot and it's time for a waterpump replacement.
But it also could just be a bad hose. Check all the hoses at the waterpump and look for cracks or loose clamps.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 21, 2006
  • Apr 21, 2006
Yeppers sounds like teh pump and
other bad spots include but not limited to:
Thermostat Housing
Thermostat Housing
Thermostat Housing
Thermostat Housing
and any hose corelated to Thermostat Housing
1988WHTGT
270
Guyton, GA
Apr 23, 2006
  • Apr 23, 2006
ok, I checked all the hoses (I have the blue silicon set) and they look fine, so I guess I should move on to the waterpump. T-stat housing looks fine also.
1988WHTGT
270
Guyton, GA
Apr 24, 2006
  • Apr 24, 2006
Ok, I noticed something. I see a little green where the lower intake meets the head in the front on the passenger side. Intake gasket maybe?
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
