Hole?
  • Thread starter Thread starter VT66PONY
  • Start date Start date Jun 24, 2005
V
VT66PONY
38
Virginia
Jun 24, 2005
  • Jun 24, 2005
So I've disassembled the front suspension and I'm about to Shelby drop it...there's a hole between the original a-arm mount...is that suppose to be there?
Here's a pic.
Hole?
Thanks!
DukeGnarley
597
Auburn/Ellensburg, Wa
Jun 24, 2005
  • Jun 24, 2005
that hole isn't supposed to be there. do you have one on both sides?
V
VT66PONY
38
Virginia
Jun 24, 2005
  • Jun 24, 2005
I actually got caught up in something else so I didn't have time to remove the other side. So is that going to pose a problem? I'll have pics of the other side soon hopefully.
iskwezm
4,159
20
79
Rowland Heights,California
Jun 24, 2005
  • Jun 24, 2005
it shouldnt if you use the support plate to strengthen where the new holes will be.
V
VT66PONY
38
Virginia
Jun 24, 2005
  • Jun 24, 2005
Support plate? Is this something I need to get because there wasn't a plate behind the arm when I removed it. Thanks.
iskwezm
4,159
20
79
Jun 24, 2005
  • Jun 24, 2005
Are you relocating the upper arm???Isnt there a support plate thats used???
V
VT66PONY
38
Virginia
Jun 24, 2005
  • Jun 24, 2005
I always thought this was a "free" mod? I didn't know there was a support plate I needed to get...where can i get some?
iskwezm
4,159
20
79
Jun 24, 2005
  • Jun 24, 2005
Maybe im wrong here,but i thought I saw a plate in those kits the sell
V
VT66PONY
38
Virginia
Jun 24, 2005
  • Jun 24, 2005
I think i'm gonna have those holes welded up so no biggie. And I'm pretty sure I won't need a plate. Thanks.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Jun 25, 2005
#10
  • Jun 25, 2005
  • #10
Plates are not required when doing the Shelby mod. The plates are primarily jigs to help locate the holes.
You can use a paper template to mark it or you can measure 1" down from the lower holes and then either 1/8" forward (or to the rear, depending on the side of the car.)
Go ahead and have the hole wielded, but first make sure that there isn't any other reason to doubt the strenght of the shock tower.
V
VT66PONY
38
Virginia
Jun 26, 2005
#11
  • Jun 26, 2005
  • #11
So when its the driver's side I go 1/8" to the rear and the passenger is going forward an 1/8"?
T
tweet66
589
Pennsauken, NJ
Jun 26, 2005
#12
  • Jun 26, 2005
  • #12
be careful
The Shelby drop on a 65/66 is down 1" and back 1/8" on both sides. This is done to gain more caster as well as a better camber curve
V
VT66PONY
38
Virginia
Jun 26, 2005
#13
  • Jun 26, 2005
  • #13
Thanks! I thought what I had said in the previous post sounded a little funny. This clarifies things. Now back to work!
dennis112
1,561
36
79
Jun 26, 2005
#14
  • Jun 26, 2005
  • #14
My BAD, As mentioned by the other poster's, the holes get relocated to the rear.
A
Help Needed! 2012 S197 brake caliper dimensions
  • AussieDavid
  • Mar 28, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 28, 2026
AussieDavid
A
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
D
What's it Worth? 76 Cobra 2
  • dulcimerbob
  • Sep 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Sep 12, 2026
dulcimerbob
D
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
