ok this is my setup
68 mustang 2900 lbs
302 bored 30 over
weiand accel intake
trick flow twisted wedge heads
decent cam cant remember duration
t-5
4:11 gears
paxton supercharger 8lbs boost
750 holley 4150 blow thru carb
this is my problem:
off idle with a jump no bog, however when im driving and crusing in lower rpm's and jump on the throttle it stumbles. When the rpms are higher it really doesnt bog. But i noticed wot thru first to second fine and then going into third it has a slight bog and the wideband goes lean. where should i start on my accel pump?
carb setup:
70 front jets
72 rear jets
37 front accel nozzle
35 rear nozzel
ive tryed switching the nozzles front front to back and it made it worse so im thinkin the front ones needs to be bigger. should i set it up to a 50cc pump? ive played with all the cam adjustments and it seems just to get worse. im running the pink cams in the first slot. the bogg is horrible but i want my carb running tits! lol.. thanks guys i know ur holley freaks up in here
68 mustang 2900 lbs
302 bored 30 over
weiand accel intake
t-5
4:11 gears
this is my problem:
carb setup:
70 front jets
72 rear jets
35 rear nozzel
