  • Digital Self-tuning Forum
Holley High-ram tuning settings
  • Thread starter Thread starter spencergt66
  • Start date Start date Apr 1, 2026
First Prev 2 of 2
X-cam34
88
27
28
ten
May 9, 2026
#21
  • May 9, 2026
  • #21
Good deal, I left your settings added my Spark and AFR tables, scaled my VE to 19lbs injectors. I also have an X cam so maybe...
spencergt66
25
Camano Island Wa
May 10, 2026
#22
  • May 10, 2026
  • #22
OK so I got the tune loaded last night and still the same cant rev the darn thing runs just nasty pig rich its like all the changes have little to no effect on this dam thing.
X-cam34
88
27
28
ten
May 11, 2026
#23
  • May 11, 2026
  • #23
sorry i am out of ideas here., just being real with you .
spencergt66
25
Camano Island Wa
May 12, 2026
#24
  • May 12, 2026
  • #24
Still seems like this dam dual sync distributor is losing spark, I can see the signals are still fine on the scope but the high voltage side just randomly seems like it has no output ive tried multiple timing lights and they all seem to intermittently work . I did some reading looks like the holley dual sync distributors have alot of issues. I was alble to call summit and they sent me a new one should be here tomorrow. If that dont work I do have a bic lighter
Reactions: gkomo
spencergt66
25
Camano Island Wa
Jun 17, 2026
#25
  • Jun 17, 2026
  • #25
Small update..... New distributor installed no change sent the ECU to AMP EFI to check to see if there was issues they said nothing is wrong with it. I have worked remotely with 2 different tuners for several hours and still dont work . I still think theres something wrong with the ECU but I was told its just fine but I still think otherwise..... Ill reach out to them again but at this point im about ready to take all this MegaSquirt stuff off and put it in the trash
X-cam34
88
27
28
ten
Jun 17, 2026
#26
  • Jun 17, 2026
  • #26
can you upload your current tune and a fresh data log if possible could you drive the car a bit....
spencergt66
25
Camano Island Wa
Jun 18, 2026
#27
  • Jun 18, 2026
  • #27
The car barely runs never has you cant even rev it acts like the timing is way of but changing the tooth offset from 0-400 degrees changes nothing its pretty special
R
rwfid
Idaho Falls, ID
Jun 18, 2026
#28
  • Jun 18, 2026
  • #28
Which tune are you currently running, and specifically which distributor are you using now?
spencergt66
25
Camano Island Wa
Jun 19, 2026
#29
  • Jun 19, 2026
  • #29
Still tunning holly dual sync but only using it for the cam sensor have a 36-1 toothed ring on the crankshaft for the CS
  • CurrentTune.msq
    CurrentTune.msq
First Prev 2 of 2
J
89 2.3 LX running rich, hesitation on acceleration, high and hanging idle Help!
  • jpstucky
  • Jun 13, 2023
  • 2.3L (N/A & Turbo) Tech
3K
2.3L (N/A & Turbo) Tech Jun 15, 2023
jpstucky
J
Fuel Fuel Pump Rewire, New Fuel Lines, and Installation of New Fuel Pump Hanger with AN6 Connections
  • AeroCoupe
  • Mar 12, 2023
13K
Fox 5.0 Mustang Tech Apr 16, 2023
AeroCoupe
L
Microsquirt pnp from EFI Source Timing setup issues
  • Lemonjohn92
  • Feb 7, 2021
4K
Digital Self-tuning Forum Feb 18, 2021
a91what
M
Engine 87 Foxbody Hesitation at High RPMs
  • Matthewhh
  • Aug 6, 2020
7K
Fox 5.0 Mustang Tech Aug 11, 2020
08GT500
High engine coolant temp
  • 85Punisher
  • Sep 29, 2019
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2019
marcelo
