I just got back from dropping the revised turbo kit at Olympic for ceramic coating.
There was so much changed on the car all this time around I made a list, it has been a long time coming but I am 3 weeks away from having it back !
Engine
Dart 364 Iron Egale
4030 Forged Egale crank
4030 Forged rods
ARP 2000 rod bolts
Diamond 26cc dished pistons
TD shaft mount rockers
AFR 205 heads
Edelbrock super vic efi
Custom Jay Allen cam
Canton 7qt oil pan w/pick-up
Fidanza Billet Alumn flywheel
Romac balancer
FMS Timing chain
Chrome alloy pushrods
Probe linked lifters
PA performance 200 amp alt
T-76 Turbo
Trans
Viper t56
MGW shifter
custom steel driveshaft
Southland 4 puck clutch/pressure plate
Fuel system
Glens sumped tank
-12 feed line -8 return
Weldon 2035 fuel pump
Weldon 1:1 regulator
Weldon fuel filter2
Weldon dial a flow
Suspension
Bilsteins shocks and struts
MM front coil overs
MM K member
MM A arms
MM rack bushings
Rear End
31 spline axles
31 spline Dertroit tru-tracker
T/A girdle
3.27 rear gears
Misc.
Corbeau Legacy seats
New paint lowers
10th anniversiary Cobra wheels
Engine bay smoothed and painted
PLX-R500
E-Boost2 controller
Engine
Dart 364 Iron Egale
4030 Forged rods
ARP 2000 rod bolts
AFR 205 heads
Romac balancer
FMS Timing chain
T-76 Turbo
Trans
Viper t56
MGW shifter
Fuel system
Glens sumped tank
Weldon fuel filter2
Weldon dial a flow
Suspension
MM front coil overs
MM K member
MM A arms
MM rack bushings
Rear End
31 spline axles
T/A girdle
3.27 rear gears
Misc.
New paint lowers
PLX-R500
E-Boost2 controller
