Engine:
363ci Ford Windsor
Dart Iron Sportsman Block
AFR Street Port 185cc Aluminum Heads
Additional Mild Port work on Heads
Ferrea Beehive Valve Springs
Ferrea Titanium Retainers
ARP Head Studs
Cometic MLS Head Gaskets
Ford Racing Aluminum Valve Covers (tapped for 4 -12 breathers)
Comp Cams High Energy Pushrods
T&D Roller Lifters
Trick Flow Billet Dual Timing Chain
Edelbrock High Performance Water Pump
Comp Cams Custom Grind Turbo Camshaft
Powerforce Harmonic Balancer
Clevite Rod Bearings
ARP Rod Bolts
Diamond Forged Pistons .30 over
Scat Forged H-Beam Rods
Scat Forged Stroker Crank
Clevite Main Bearings
ARP Main Bolts
Splayed 4 Bolt Billet Main Caps
Canton 7qt Oil Pan
March Aluminum Pullies
Cooling System:
Ford Racing Aluminum Radiator
160degree Thermostat
3600cfm Twin Electric Fans
Custom Aluminum Fan Shroud
Upper Radiator Hard Pipe
Lower Radiator Hard Pipe
Custom Aluminum Overflow Can
Custom Aluminum Breather Can w/twin 2 inch filters (5 -12 AN Fittings + Braided Lines)
All new seals, gaskets, bearings
Fuel System:
Injector Dynamics 1000cc Injectors
Trick Flow Billet Fuel Rails
Twin 255L Walbro Fuel Pumps
Complete Insane Speed -10 Hardline E85 Safe Fuel System
Trick Flow Fuel Pressure Regulator
AEM Water/Meth Injection System
Kenne Bell Twin Boost-a-pump
Electronics:
MSD 7AL2 Plus
MSD HVC II Coil
Accel Dual Sync Distributor
MSD Plug Wires
130 Amp Alternator
Fast XFI w/data logging + TC Stand Alone
Turbo System + Intake:
Edelbrock Performer RPM II Intake Manifold (weld fitting tapped for -12 breather line)
ARP Manifold Bolts
Trick Flow 75mm Throttle Body
Precision 6765 Billet Wheel Dual Ball Bearing Turbo
DEI Turbo Blanket
Insane Speed Stainless Turbo System
Insane Speed Custom 850hp Intercooler (Spearco Core)
Insane Speed Custom Aluminum Intercooler Piping
Turbosmart 50mm Wastegate
Turbosmart Race BOV
Aluminum 4 inch intake
K&N 4 Inch Filter
Exterior:
Clear Headlights
Bi-Xenon HID Headlight Conversion
Smoked Taillights
15% Tinted Windows
Cervini 2.5 inch Cowl Hood
Saleen Whale Tail
Cobra Grill w/Pony Emblem
GT Front Bumper (wider mouth cut for intercooler air flow)
Cervini's Cobra Spats and Side Skirts
Cervini's Cobra Rear Bumper
KC 5 inch HID Fog Lights
Cobra R Wheels Chrome
295/45/17 Mickey Thompson ET Street Rear
245/45/17 Michelin PS2 Front
Painted 2011 Ford Kona Blue
Suspension + Rear End:
Eibach Lowering Springs
Tokico Illumina Shocks
Eibach Urethane Shock Bushings
Eibach Urethane Control Arm Bushings
Eibach Sway Bars
BBK Rear Upper Control Arms
BBK Rear Lower Control Arms
BBK Urethane Control Arm Bushings
Kenny Brown Full Length Weld In SubFrame Connectors
Kenny Brown Extreme Matrix Bracing
Kenny Brown Jacking Rails
Custom Chromoly Rear Under Bracing
Upper + Lower Heavy Duty Torque Boxes (welded in)
Maximum Motorsports Front Strut Bar
Maximum Motorsports K-Member Bracing
Custom Rear Strut Bar
Completely Seem Welded Chassis
Ford Racing 3.27 gears
Ford Racing 31 Spline Cobra Posi w/carbon fiber clutches
Moser 31 Spline Axles
Moser Wheel Studs
C-Clip Eliminator
Ford Racing Aluminum Driveshaft
Chromoly Spicer U-Joints
UPR Rear End Bracing
UPR Billet Stud Girdle
UPR Urethane Rear End Bushings
Welded Axle Tubes
Exhaust:
Insane Speed Stainless Turbo Headers Coated Ceramic Silver
Insane Speed Stainless Crossover Pipe Coated Ceramic Silver
Insane Speed Stainless 3 inch Downpipe Coated Ceramic Silver
Insane Speed Stainless 3 inch Midpipe X'd into Dual 2.5 inch Exhaust Coated Ceramic Silver
Cometic Header Gaskets
Stage 8 Locking Header Bolts
Flowmaster Mufflers and Tips
Transmission:
TKO 600 Transmission
Upgraded 26 Spline Shaft
Insane Speed Tubular Chromoly Trans Cross Member
Urethane Cross Member Bushings
Urethane Trans Mount
Centerforce Twin Disc Clutch
Kevlar Pilot Bushing
Pro 5.0 Short Shifter
Rally Style Shift Ball
Autometer Boost Gauge
Autometer Coolant Temp Gauge
Innovate Wideband Gauge
Below Radio Gauge Mounting Plate
Interior:
New Black Interior Conversion:
Dash Board
Dash Pad
Glove Box
Cabin Carpet
Hatch Carpet
Hatch Mat
Center Console
Ash Tray
Leather Armrest Pad
Scuff Plates
2008 GT500 Black Leather Seats
Brakes:
Short Stop Front Slotted Rotors
Hawk Street Pads
Stainless Steel Brake Lines
363ci Ford Windsor
ARP Head Studs
T&D Roller Lifters
ARP Rod Bolts
ARP Main Bolts
Canton 7qt Oil Pan
Cooling System:
Fuel System:
Electronics:
MSD 7AL2 Plus
MSD HVC II Coil
MSD Plug Wires
130 Amp Alternator
ARP Manifold Bolts
DEI Turbo Blanket
Turbosmart Race BOV
K&N 4 Inch Filter
Exterior:
Clear Headlights
Smoked Taillights
15% Tinted Windows
Saleen Whale Tail
Eibach Sway Bars
Moser Wheel Studs
C-Clip Eliminator
Welded Axle Tubes
Exhaust:
Transmission:
Interior:
Dash Board
Dash Pad
Glove Box
Cabin Carpet
Hatch Carpet
Hatch Mat
Center Console
Ash Tray
Leather Armrest Pad
Scuff Plates
Brakes:
Hawk Street Pads
= Kona Blue
