Same here!98MACH1R said:have you never heard of the ten inch drop lol all i do is drop it from about ten inchs and it always closes for me![]()
twogts4us said:Same here!
But on my wife's that doesn't work as well as on mine. On hers, I have a different technique - I lower it until it just catches the latch, then I press down firmly and it locks.
n0v8or said:I shimmed the entire latch bracket (the one mounted at the top of the radiator) up 1/8" with two plastic shims. Now I just close the hood gently, then push down lightly to latch it. Still works fine after 2 years.
GT-03 said:That is what I did with my '03 too.
IMHO, it is better than removing the pins off the latch itself.
n0v8or said:You have to remove the plastic radiator cover first, and then loosen or remove the latch brace rod connection from below. Finally, remove 2 (or maybe 4, it was more than 2 years ago) bolts to remove the entire bracket and latch assembly. Removing just the latch is not effective because it is pinned to the bracket at the factory after the final adjustment on the assembly line.
kapuyawn said:Can You post pics of the shim setup on your stang?
would love to see how it should be installed.
Thanks a bunch!
