hood latching ?'s
  • Thread starter Thread starter Marlboro_Man
  • Start date Start date May 30, 2006
M
Marlboro_Man
437
Houston, TX
May 30, 2006
  • May 30, 2006
I was wondering if there is a reason or a fix for this little problem which seems to be pretty common on fox's.
When i go to close my hood i have to "drop" it . Slowly closing the hood and then pushing it will NOT latch it. I have tried oiling/wd-40ing the latch components as well as making sure everything lines up , which it seems to. As well i have tried lowering and raising the hood stops with no avail.
Anyone else have this problem or have a fix for it?
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 30, 2006
  • May 30, 2006
Mine is like that too. is there a way to adjust it I've never looked. The first say with my car I took my friend for a ride after showing him under the hood. I got up to about 100 Km's and hour and the hood poped up a little to the secondary latch or whatever you call it. I slammed on the brakes locked up the front tires and had to get out and slam the hood....The guy I was with has a 86 IROC and hasn't had his car on the road since....He said it wont be on the road untill he builds a new motor that will spank mine..I told him "you better make a good one cause I got plans for this one"
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
May 30, 2006
  • May 30, 2006
Sorry man, every single Fox Mustang I have ever owned needed the "drop shut" method to engage the hood latch. It probably has to do with the design of the lock cam and not the springs or amount of oil on the moving parts. The profile of the latch cam is probably too steep to trigger the lock when not enough force is used.
bubba-dough
1,044
Indiana
May 30, 2006
  • May 30, 2006
There is a little adjustment on the latching system (as far as moving the latch around a bit). We had to mess with mine when i got the fiberglass hood. Also after switching to the fiberglass hood mine still needs a liitle force....not a drop shut though. On my pals, he just has to gently push it down????
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
May 30, 2006
  • May 30, 2006
2004 mustang GT....still suffers from the drop latch issue...it's a ford thing, they all do.
M
Marlboro_Man
437
Houston, TX
May 30, 2006
  • May 30, 2006
I kinda figured that, I just fear that i'm going to crack my harwood one day from it.
pb_paulie_b
894
Chaptico, Maryland
May 30, 2006
  • May 30, 2006
Been doin that to my Harwood for years
I'm sure it's the way the mechanism was designed for a heavy azz stock hood. Our light figerglass hoods require the ol' drop method.
Hickfied
413
Morganton, NC
May 30, 2006
  • May 30, 2006
My stock hood is fine... I can set it down, then press on it firmly and it closes just fine, but the hood does sit pretty close to the bumper cover...
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Hood latch connector
  • skkrtis
  • Aug 3, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 3, 2025
skkrtis
Drivetrain Hood latch/cable issues
  • AnthonyA1234
  • Nov 1, 2024
Fox 5.0 Mustang Tech Nov 20, 2024
AnthonyA1234
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
R
Convertible top not closing
  • Ray _Sleeper
  • Jun 27, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 27, 2025
Ray _Sleeper
R
