Hood Pins?
Hey, When i installed my hoods pins i did not scratch the hood. Although, the kit like mine had a chrome ring that went around the hole(On the outside of the hood), so if i had scratched it some it would of covered the scratches. I highly suggest putting some sort of paint on any scratches or holes you drilled so it does not rust(If your hood is steel). Good luck!
if this is a stock metal hood, i see no need. but if you do decide to do it, i'd use some seam sealer around the hole you drilled or it WILL rust.
just use a hole saw and a pilot bit. i think the hole is like the size of a nickel or a penny, i can't remember
