  • SN95 4.6L Mustang Tech
Hooker Header Install Issues
  • Thread starter Thread starter Brian*04*GT
  • Start date Start date Aug 16, 2005
Brian*04*GT
Louisville, KY
Aug 16, 2005
  • Aug 16, 2005
I recently installed some Hooker long tubes on my stang this past weekend. I have a couple of small issues that I'd like to get worked out, but dont seem to be a big deal. Just wondering if anyone had similar problems and how they fixed them.
#1 - The driver side header is 2-piece, if I recall, to go around the steering assembly. Where the two pieces join together, its not sealed tight and I have a small leak. What would be the best way to seal that??
#2 - Same side, different issue. Where the steering assembly goes through the header, it rubs VERY slightly when I turn just to the left or just to the right. Its not binding or anything, just a little tap thats somewhat noticeable. Anyone have that problem and how did you fix it??
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Aug 16, 2005
  • Aug 16, 2005
tap it with hammar unitl it clears shaft?
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Aug 16, 2005
  • Aug 16, 2005
http://forums.modulardepot.com/show...34&perpage=20&highlight=flowtech&pagenumber=2
Use RVT around the the slip fit, and use a clamp (SME-240275 from summit), and let it sit over night.
There are some pictures in that link
stangman
2,690
10
69
in a 3 bed, 2 bath
Aug 16, 2005
  • Aug 16, 2005
make sure to put a cloth over the header tube & to not beat the crap outta it. take it slowly & not go too far
mity2
Jul 24, 2003
2,872
StateCollege PA
Aug 16, 2005
  • Aug 16, 2005
i said "tap it" , not "smash it to obrivion as if your header is made by Saddam"lol
stangman
2,690
10
69
in a 3 bed, 2 bath
Aug 16, 2005
  • Aug 16, 2005
nice engrish
you have to be veeedy, veeedy clear with some people. you know that's true, so i thought i'd clarify
mity2
Jul 24, 2003
2,872
StateCollege PA
Aug 16, 2005
  • Aug 16, 2005
lol
BooWFO
991
Louisville, KY
Aug 16, 2005
  • Aug 16, 2005
Hey man didn't want to post up on LM Anthony seemed to be a little "antsy" anyway the clearance Hammer or a pry bar and be gentle. The leak my dad uses some Exhaust puddy when they have one they can't seal. I'll have the real name in a few if that don't do it nothing will. You can either Pm me on here or LM I check both through out the day and night.
BTW We're running Wed. if the rain isn't in you should bring yours out.
'00 hi-po
  • Aug 16, 2005
Do Not hit the headers w/a hammer.Heat them up(torch), then dimple it slightly with a bar.This way it's easier to bend the right amount and it will not weaken the tubing.With my Hookers I had to do it in a couple of spots but,now,it's perfect.Good luck.Also ,that exhaust leak on the primary will seal itself w/ a little carbon build up.It just takes a while.
P
Electrical 2001 GT Overcharging
  • PseudoGT
  • Dec 3, 2025
SN95 4.6L Mustang Tech Dec 13, 2025
D
2006 GT Windshield Cowl install
  • Daddidio
  • Mar 12, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 12, 2026
Daddidio
D
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
