Hopefully won't get flamed for this here
  • Thread starter Thread starter kpack5982
  • Start date Start date Aug 23, 2007
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
Aug 23, 2007
  • Aug 23, 2007
I thought about putting this in tech, but i know there are a lot of write-ups places for both of these, but I am a very detail oriented guy and need A LOT of details. So here she goes...
I am installing a 3g from a 94 in my 93 and find write ups and a lot have little different tidbits of info. So I am wondering if someone can give me a write up with EXACTLY what to do, INCH by INCH. I am terrible with electrics so I need help. The only problem is that I know something about an extra 4gauge ground wire or something and want to do that, so please help me with including that.
At the same time I am installing a mark Vii fan, which is all prefit into the stock fan housing, just needs to be hooked up. Until I decide on the DC controller, temp sensor, whatever, is there a way someone can tell me how to hardwire the fan to a switch, so I can turn it on and off?
Thanks a lot guys and sorry for the novel.
88mouse
630
Mooresville nc
Aug 23, 2007
  • Aug 23, 2007
http://forums.stangnet.com/showthread.php?t=646825
Did you look there?
Metalcop
148
New Hampshire
Aug 23, 2007
  • Aug 23, 2007
This is the best one that I have seen, on the net:
http://www.mustangcentral.net/tech/alternator.html
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Aug 23, 2007
  • Aug 23, 2007
http://www.paperformance.com/scripts/prodList.asp?idCategory=40
I used there instructions (I do not recall which one it was) and it was colored and step by step, and I am like you, detail oriented with not much knack for electronics...
Paperformance also has a complete kit (minus the alternator, unless you want it) to install it. You could order it and the correct instructions over the phone:
http://www.paperformance.com/scripts/prodView.asp?idproduct=89
kpack5982
Jul 13, 2005
325
Granger, IA
Aug 23, 2007
  • Aug 23, 2007
Thanks guys, just what I needed. Now how about the fan install? Can I use just a switch or do I have to have a dc controller and all that jazz?
R
RycheGT
73
Thomasville, NC
Aug 23, 2007
  • Aug 23, 2007
you can run a switch so you can turn it on and off on your own. just make sure you use a good quality 30 amp switch. those fans pull a good bit of juice and a crappy switch will fry quickly.
HISSIN50
34
129
Aug 24, 2007
  • Aug 24, 2007
That fan can pull a start-up draw of over 100 amps. Use a HD relay (75 amp plus) at a minimum. Dont try to put all that power through any sort of switch in the interior.
A controller is the way to go if you drive the car more than once a month.
Monte Smith has info about installing the fan (and a 3G) on his site. JRichker also has outstanding references and tech notes on each installation.
Good luck.
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
A
79 mustang pace car spoiler.
  • Anglosaxon83
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2026
Anglosaxon83
A
