Guys I pulled my rear cover today and replaced it with a trick flor girdle. Noticed the pinion sela leaking so removed the d-shaft and marked the flange and nut and shaft. I pulled the flange after counting 13.5 turns on the pinion nut to remove. Replaced the seal and reinstalled all.
Now I have a horrible groaning noise taking off in first, once shifted in 2nd it starts screaming bad. Just made it around the block and came back. Im a little confused, I might remove the whole rear and set it up, but I did check back lash when the cover was off, it was ok and no noise prior to this repair.
The only thing I changed with I rotated the drive shaft 1 bolt hole to the left, the other holes were very rusted and hard to tighten.
