hot starts....annoying....
VIPERn94Five-0
3,352
Poughkeepsie, NY
when i go to start my car for the first time of the day it starts like a champ...and when the temp needle is below the normal sweep its fine...but if i run the car for a while and the car doesnt sit for a long period of time sometimes it just starts like crap...sometimes it will just crank, and crank, and crank....it only does this when warm....
....another issue...when the car first starts up....the first one or two times i brake to a stop the revs die, it doesnt shut off but they drop down real low and then kick back up....this issue i think i may have narrowed down to an old fuel filter/worn out fuel pump because it seems like it happens when im around a 1/4 tank or lower.....
....would the fuel filter/pump cause problem #1 by any chance???
Anthony
My car had the same hot restart problem as yours when it was bone stock. If I stopped somewhere to get gas it would just crank and crank. Id have to let off the key and then hit it again to fire. After I installed the intake and TB I never had it again, and that was 4 years ago. This is common problem for the 94-95s. Some say the ACT sensor being away from the manifold causes it, but if that is true why did mine stop?
Your second problem is really common as well. Sometimes the computer is just a little slow. My car use to do it a lot when cold and it was N/A, but since the blower addition it has never done it. Knock on wood I guess.
i guess just something ive got to learn to deal with huh?....im still gonna swap out that old fuel filter (had a new one sitting around for months just have had the drive to get down there and do it)....it cant hurt since im pretty sure its original....67k OUCH!
Anthony
Mines doing all the above. If you find an answer let me know. I don't have the funds right now to throw parts and sensors at it.
The part about slowing down for a stop sign is REALLY bad. My alternator charge dances all over the place and the stock tach drops to 300 rpm. It's even died a couple times. I was curious if the under-drives were dropping the charge level so much that it was causing the pump to not have enough voltage to pump the fuel??
I now stop with both feet and touch the gas as I stop. I also thought it could have something to do with my brakes. The rotors are warped pretty bad. Now that the auto-x I was running in is over, I'm going to change those out. I hope that helps the situation. :shrug:
I'll try to post back with results....
This problem is very typical of a bad fuel pump. I have had 2 fuel pumps crap out on me with the same symptoms described. The car will start fine in the morning, however after you go to the store or the car gets realy hot and you stop somewhere, it takes a long time for the car to restart. Eventually it will die and leave you stranded somewhere until the car cools off, then it will turn back on, but for a little while only. Worth taking a look at.
Having this problem right now. Same problem I had in my 89 5.0. Is there a better fuel pump that can be bought, cause obviously, the factory fuel pumps aren't worth s**t. :notnice:
I wouldn't chalk it up completely to a bad fuel pump...
I've tried two new Walbro's since I've had this car and it usually will not hot start good at all. Typically if I stop at a gas station the car will not restart for about 5 mins. I don't know what the gremlin is. It just turns and turns but won't hit at all.
SS
Someone suggested to me that it might be my TFI module causing this problem. That being the case then I have three questions:
1. What is a TFI module?
2. Where is the TFI module on my car?
3. Is there a way to test it for faultiness?
You can buy Walbro 255lph pumps for about $100 bux, just check around. Anything is better than the stock pump. All the Mustang mags will sell them so you can look there, although i would check classifieds here or on Corral....tons of them for less than $100.
I had this problem and I'm sure it was my original starter. After getting hot it would "heat soak" and not start until I let it cool off some by opening the hood. The starter drages and pulls more current than normal which drops the electical system voltage below the point that the coil can keep the spark high enough to jump the plug gap. After putting Jet-Hot ceramic coated headers and a high torque mini starter in my car, the problem is long gone and I have had the same TFI and distributor stator in since I bought the car.
I did a search at Google on TFI modules and found this:
http://www.autosafety.org/article.php?scid=&did=362
Most of it is recall crap but there is one part that refers to the problem it causes:
This sounds like what could be buggin' my car. So I'm going to try this first, and if that doesn't cure it then I'll try the fuel pump. These things are only about $50-$60 bucks and a hell of alot easier to change than a fuel pump, but don't go looking for them on the distributor on SN 94-95 cars. They moved them to the passenger side fender, under the air filter.
The TFI was moved under the air cleaner assembly to promote better cooling across the device. Ford will NEVER admit the TFI was put in a bad spot when mounted directly to a heatsink on the distributor itself, but ask any auto parts guy who's been there a while and I'm sure he's sold a lot of TFI's that were mounted directly to the distributor, above or on the side of a hot engine.
My dad's been through about 5 of them on his 1985 Ford F-150. The better job you do smoothing the dieletric grease to promote heat transfer, the longer they lasted...
So go figure.
The TFI failure is usually indicitive of no start when hot, starts right up after sitting a while...so a TFI replacement is a good first step, however they are not as much of an issue on our year's cars since they have been relocated to a cooler place.
SS
Are any of you getting any spark when this happens? I would check for those problems as well like your coil, dist.stator and plugs. I would listen if you hear your pump engages by just turning the key to the on position. :shrug:
That's what I figured too, but under the hood of my car anyway, I doubt there is any cool spots. And it's not that the car runs too hot,
the temp gauge never gets past half way, then the fan kicks in and brings it down to around a quater.
I'm having doubts about it being the fuel pump either because I can hear it everytime I turn the the key to the "ON" position, plus I checked the it at the schrader valve a couple of hours after it had been sitting, and still had lots of pressure. Mind you I just stuck a screwdriver in it, and a big gusher of gas came out. I didn't actually pressure test it with a guage.
gcomfx.com said:
I subscribed to this thread.... let us know how it works out for you. If it works for you, it's worth $60 to try here, and I'll post my results back too. Maybe we can keep a small record for future viewers.
I won't be changing it till at least Wednesday, (payday), but I'll definitely keep ya posted.
I have a similar problem, my car will start but I have to put my foot to the floor. It usually starts. This problem appeared after I replaced my head gasket. My car will start perfect in the morning,after driving it for awhile it will start to run really rich and stall or idle real bad. I have replaced sensors but no change. I have noticed that the fuel pressure gauge seems to jump around when the car starts to act up. My first thought was the fuel pump but its new along with the filter,wires,cap,rotor,distributor,and related sensors. I haven't a clue,it ran faster,and flawless before the h.gasket went.
