Hot wire help
Use the Red/green wire coming off the ignition switch. Be sure to fuse it to protect the ignition circuit.
If the circuit will pull more than 2-3 amps, you will need to use the Red/green wire to trigger a relay that draws power from the battery connection on the starter solenoid.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
I'm asking this cause i'm installing a fast XFI stand alone and they want me to wire a single wire off the fast dizzy to a wire thats hot all the time when the ignition is on as well as when your cranking it.It would be safe to say i could use the Red/green wire? peace
john:p
As you can see, the Red/Green wire that JR noted is what supplies power to the OEM ignition (amongst other important components). You would be hard pressed to find a better source.
