How BAD is this?
66 Tiger
249
Virginia
Well I was getting ready to install my heads today & while cleaning off the block I decided to remove the carbon off the pistons too.
This is my first time changing out heads so this may be normal but I instinctively put on the brakes after discovering what looks like little cracks in the tops of some of the pistons.
My question is exactly that - Is this indeed normal wear & tear or instead am I in need of a rebuild.
Any advice would be greatly appreciated...
Heres a few pics:
I agree, They do look like some type of casting lines. If your really worried send the pics to Manley's tech line. Do you have a picture of your car? If so I'd like to see it. I wish I know how to attach BIG picture files like that....:hail2:
Set up a photobucket.com account (free) and you just copy the location of the photo when it has [img/]
Thank's everyone!:hail2:
What a relief. I haven't even driven the car yet ( other than around the block at delivery ) & having the motor rebuilt would just delay the process even longer.
Yee, haw...
:D I noticed it needed a coolant flush too. Other than that it doesn't look like a crack at all; use 'em!
LOL! Yes, It definitely NEEDS a coolant flush. I'm kinda bummed out about installing my nice & clean re- built heads with all that gack through-out the motor, water pump, hoses & whatever else it may have attatched itself to.
When I first got the car it had been sitting for almost five years so I figure thats where alot of the corosion has come from?
Check out the thermostat housing:
Yep - Just like Z06killinSBF said, set up a photobucket account & simply paste & copy the URL Link into your thread.
http://s2.photobucket.com/
I dont really have any good pics of the car right now because as soon as I got it I parked it in the car port, set it up on stands, & went to work. Its been this way since September.
Heres one for you: ( LOL - notice the crooked trim strip expertly installed by the PO )
Did you get the heads out with the motor still in the car? I've seen a couple Tigers and you must be very flexible to pull that job off! Neat car btw.
Thanks.:nice:
Basically I just had to raise the vehicle & then by unbolting the motor-mounts I was able to lower the engine just enough to get the heads off.
The motor-mounts are actually bolted through the inner fenders which make detaching from the car anyway, a pretty easy task.
As for everything else that I have encountered - your absoulutely correct in having to be flexible. ( both mentally & physically )
i've always wanted a Tiger, i think of them as a poor man's Shelby, but when you are talking about a Tiger "poor" is kind of a relative term. i used to watch Get Smart on tv after school just to see the Tiger. i like those mesh style wheels on it too but i'm kind partial to that style of wheel.
ps, ditch the chrome stat housing as they always warp really bad, it looks your's is already well on it's way to warpville.
Don't worry about those casting flaws. I've got a brand new set of Manley pistons in the box still and they have casting lines on them as well. As long as there aren't any dents from valves smacking them, you're good!!!
