Well, the computer does
think it knows something about the cam...
There is a setting for 'Injector Timing'
This setting (a table) determines when the injector for each cylinder fires.
Firing the injector when the exhaust valve is still open can result in spraying fuel directly out the exhuast valve.
The ecu has already calculated the 'correct' pulsewidth, but with some of the fuel dumping out the exhaust, you may end up with a lean mixture in the combustion chamber?
Also, when the fresh air and fuel charge hits the O2, the O2 will read lean.
These are some of the reasons that large overlap cams can cause efi issues...
I'm not sure on that though... there are more factors there than I care to think about right now... 3/4 into a six pack...
Instead of asking 'How much cam can the ecu handle?'
Ask something like 'What cam specs will provide the results I'm looking for?'
Duration is a function of the valve events. A cam designer will select the valve events, and then calculates the duration @.006 and @.050 from the open and close events.
Duration on its own is pretty useless.
If you are
SERIOUS about getting the
RIGHT cam for your setup...
Look up Jay Allen
http://www.camshaftinnovations.com/
Or see the 'Custom CI Cam' link in my sig...
(guess where my cam is coming from!!!!!!!!!)
Random thoughts,
jason
