How can I pass emissions? Is there any hope?
these are my mods...
12:1 compression
Prime-Performance 351w Crate engine
Edelbrock Torker II intake
1.6 Roller Rockers
Trick Flow Twisted Wedge Heads Highport model
FRPP F303 Camshaft (512/512 lift. 280 duration)
FRPP Aluminum D/S
Centerforce Clutch
Flowmasters 40's series mufflers
FRPP Shorty headers
Offroad Hpipe
FRPP 3:55 Gears
MSD 6AL Ignition box
MSD Billet Distributor
Accel Wires
Holley 750 double pumper
CGS subframe connectors
Holley Blue Fuel Pump
Trick Flow Chromeolly 6.5" pushrods
Hurst shifter
Metal Clutch Quadrant
Sunpro Gauges
Dunlop Drag Radials on rear
How can I pass emissions? Tryed yesterday after installing catalytic convertors. still failed. Any ideas?
Passing emissions with a carb? On a car that has specs for the efi engine? In most places you'd have been failed simply for removing the fuel injection. There's not a hope in hell that you'll pass with that combo in my opinion. You didn't really think you could did you?
On the other hand, it's Louisiana. Isn't there someone you can simply 'buy' the sticker from?
Try backing off the air-fuel ratio until the car is stumbling and barely running (possibly even stalling) -- that will probably get you by or close at idle. You're probably fine on the rollers (if you have to go).
Maybe post the emissions readouts and we can see what to do from there.
Round these parts, if a car does not have its original engine, they will allow you to pass emissions based on "1980" standards, whatever that means... [as far as limits or readings..] but it's for cars that have been hot rodded, or had to buy a "new or diff engine", and from what i've heard the standards are a joke.. EFI cars w/ no cats around here [EFI Irocs and done up Stangs w/ 347s] have passed the 1980 standards E test..
Nuthing like that there?
How do you spell EFI conversion -$$$. It's probably the only way you'll ever pass the sniffer test.
Aside from that, post the HC, CO & NO results you got and what speed the sniffer dyno ran when it got them. There may be one or two tricks to do with a carb'd engine, but I wouldn't hope for too much.
