FastGT94 Member Nov 20, 2003 300 0 16 NW Burbs, IL Jul 12, 2004 #1 Jul 12, 2004 #1 I'm chasing down a lean condition and want to know if there's a way for me to check and see if my Adjustable Fuel Pressure Regulator is bad. Thanks
explorerguy96 New Member May 8, 2004 14 0 0 Jul 12, 2004 #2 Jul 12, 2004 #2 there should be a fuel line connected to it, just unhook the fuel line, and if it leakes out gas from the regulator then you need a new one....
Yellow302 Member Mar 2, 2003 789 2 19 NJ Jul 12, 2004 #3 Jul 12, 2004 #3 I had one go bad, or was bad from the start. i would set the FP and 3 days later it would be 3 PSI higher. i would set it back again and would be lower in 3 days. finnaly swaped for a new kerbin from a bad kirbin, and a new guage setup. so far so good except for my fuel rail poped off 4 of the injectors on friday. good luck.
FastGT94 Member Nov 20, 2003 300 0 16 NW Burbs, IL Jul 12, 2004 #4 Jul 12, 2004 #4 well, it isn't leaking gas, it holds the proper pressure as long as I tighten the stop nut enough and looses pressure down to zero over about 1/2 an hour. Sound like its ok? Thanks!
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Jul 13, 2004 #5 Jul 13, 2004 #5 disconnect the Vac line to it - if there is fuel in the vac line, that suggests the diaphram is bad.
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Jul 13, 2004 #6 Jul 13, 2004 #6 i just read this and thought there may be something of interest in there, esp if more people post on it. http://forums.stangnet.com/showthread.php?t=482102 good luck.
