How can this be
  • Thread starter Thread starter KGOFF
  • Start date Start date Apr 5, 2009
K
KGOFF
63
nj
Apr 5, 2009
  • Apr 5, 2009
I was removing a harness and ecu from an 87 gt.I pulled the computer and threw it on the side.Today Im having computer problems(dumping codes and used the wrong wire!) so I try to swap it out and read the #'s.....ford taurus 3.0,how the hell did this run an 87 gt?????
dcurtis
688
Apr 5, 2009
  • Apr 5, 2009
A lot of ford computors say that on them, it is no problem, as far as pulling the codes I don't know.
K
KGOFF
63
nj
Apr 5, 2009
  • Apr 5, 2009
I also cant get codes out of the a9p,the light just stays on when i jump it....check engine is on,fuel pump running constant and car wont start sometimes????
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Apr 5, 2009
  • Apr 5, 2009
dude make damn sure you are not using the wire that powers the hood light. i did that one time and smoked the ground in the ecu
K
KGOFF
63
nj
Apr 5, 2009
  • Apr 5, 2009
LOL...did that already!!!!Got lucky so far
strtrcr50
Previously from Dirty Jerzey exit 7a
Apr 5, 2009
  • Apr 5, 2009
An a9p is not a speed density computer and shouldn't be in an 87 unless you converted to mass air. Did you convert to mass air, and if so, did you replace the engine harness or repin the factory and add the mass air harness?
K
KGOFF
63
nj
Apr 5, 2009
  • Apr 5, 2009
Car has been converted with correct harness and computer.I found the fuel pump issue,orignal owner had it jumped out??....I still can't pull codes.I hope im not useing the wrong wire,I know the one for the hood light and Im not useing thst one.
I had the car running fine for 2 days after rubuild.The car will start first thing,then after a short trip 10/15 mins it wont start?fuel pump running and it has spark.
strtrcr50
Apr 5, 2009
  • Apr 5, 2009
I had this problem with my conversion. Is your car a stick? If so, did you get a a9p and a harness out of an automatic? With mine, I put an a9p and auto harness in an 88 stick car. A signal return on the o2 harness under the maf is different between the 2. I had to move the wire that loops right around 1 hole over. Hard to describe, but when you see it, you'll know what I mean.
http://www.hardcore50.com/vbulletin/showpost.php?p=379216&postcount=18
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
