Hey guys, I had this topic going about a month ago. Someone here was nice enough to reply with a VERY detailed LONG write up. Unfortunately the server crashed and my post is gone. Someone else was on the thread with the same problem as I and we were sharing notes. Anyways, I'd like to track them down if possibe. With that said, here is my problem:
Stock 5.O. Only mods are an electric fan and cat back.
I'm getting EEC-IV error codes 44 and 94
Here is what I've replaced so far with no luck:
H pipe
O2 sensors
TAB valve
TAD valve
TAB solenoid
TAD solenoid
I have verified that the solenoids do open and there is vacuum present at both the TAB & TAD valves when their coresponding solenoids open.
There isn't much else to replace in the whole smog system:
The 1 way aluminum (flying saucer shaped) valves
The smog pump
Hoses carrying air from the smog pump
Can the 1 way valves go bad? The smog pump freely spins and I can hear it making a pumping noise (similar to an electric air compressor/pump), so I assume its working fine. I don't know what else to replace.
H pipe
O2 sensors
TAB valve
TAD valve
TAB solenoid
TAD solenoid
The smog pump
