How do i eliminate lifter tick?
  • Thread starter Thread starter olyfiveoh
  • Start date Start date Jul 13, 2005
1 of 2 Next Last
O
olyfiveoh
38
  • Jul 13, 2005
My motor has developed a pretty noticable lifter ticking. how do i get rid of this?
Car RamRod
Banned
Mar 30, 2005
623
Queens, NYC
Jul 13, 2005
  • Jul 13, 2005
new lifters.
but before that make sure that your rocker arms are nice a torqued down.
C
Carbed86GT
33
Champlin, MN
Jul 13, 2005
  • Jul 13, 2005
Also make sure you're running enough oil. Low oil can cause the lifters to bleed down.
2000xp8
SN Certified Technician
Aug 8, 2003
8,078
1,659
194
NJ
Jul 13, 2005
  • Jul 13, 2005
Also could be your rockers, some rockers have some side to side play and they cause the noise.
Paul Perreca
1,085
  • Jul 13, 2005
I heard MARVELS (comes in some kind of metal can or something) is a good additive to help quiet the tick
Paul Perreca
Car RamRod
Banned
Mar 30, 2005
623
Queens, NYC
Jul 13, 2005
  • Jul 13, 2005
I dunno I put marvel mystery oil in with diesel fuel
O
olyfiveoh
38
  • Jul 13, 2005
is it fairly easy to replace lifters? also, occasionaly, my car will back fire a bit when i shift into 2nd or 3rd. could a bad lifter casue this by holding open a valve? If i replace the lifters, could the backfire go away?
Euphoric306
905
  • Jul 14, 2005
lifters r a piece of cake...
281pony
2,681
Oly, WA
Jul 14, 2005
  • Jul 14, 2005
do you have an offroad h-pipe? alot of times that happens with an o/r h-pipe from the excess unburned fuel on a stock type motor. my 5.0 did that when it was stock.
you will need to pull the upper/lower intake to get at the lifters. take off the valve covers also, loosen/remove all the rockers to get the pushrods out of the way. once they are clear, you remove the piece holding all the lifters down and pull them out.
if you have never pulled the intake, it might be helpful to have someone there to make sure you get everything sealed up properly or you can have other issues.
rockers should be torqued to 24 pounds btw. start there. i have a set of lifters with almost no miles on them in lacey if you end up needing to buy them.
2000xp8
Aug 8, 2003
8,078
1,659
194
NJ
Jul 14, 2005
#10
  • Jul 14, 2005
  • #10
Well, first off, i'd like to ask you if you are 100% sure it's not a header gasket leak (sometimes at the head side and sometimes at the h pipe side., it happens and very often it sounds like a tick. Stick your head in there, and use your hand to operate the throttle, and if you get close enough you can tell.
Second, what type of mods are done to the car, because if you are going to pull the intake, might as well put a better one on if the money is available. Along with a set of roller rockers.
O
olyfiveoh
38
#11
  • Jul 14, 2005
  • #11
My mods are o/r x-pipe, catback, cold air kit
281pony
2,681
Oly, WA
Jul 14, 2005
#12
  • Jul 14, 2005
  • #12
im in lacey if you need some help i can talk you through it or whatever.
hell you can bring it over and maybe we can fix it without switching lifters. im bored today
O
olyfiveoh
38
#13
  • Jul 14, 2005
  • #13
i have school and work today so i couldnt today. you are going to the roundup right? maybe you could take a look at it then.
281pony
2,681
Oly, WA
Jul 14, 2005
#14
  • Jul 14, 2005
  • #14
yeah, thinking about driving sunday for the car show.
it will all depend on how my deck install goes/doesnt go. im not driving there without a cd player and listening to my damn cobra bumper rattle on the tailpipe.
O
olyfiveoh
38
#15
  • Jul 14, 2005
  • #15
so what about this backfire? it goes off in sets of twos or threes and its always when i shift into 2nd or 3rd. its coming from the engine compartment
68 MGB
#16
  • Jul 15, 2005
  • #16
I have a lifter tick in my engine of a type that has been described in earlier threads. Basically, the engine is quiet when cold, and develops the tick when warm. The noise is most noticeable between 2000 and 2500 rpm. I am running 10-30 Castrol, and fixed the problem by replacing one quart of oil with Lucas oil additive (in the earlier thread Slick 50 accomplished the same thing). I do not like this fix because i started with a new GT40 (aluminum head) crate motor and it did this from day 1. Later I replaced the B303 cam with a Comp Cams XE264 HR (.512 lift). Lifter preload was fine. The noise got worse over the next 5,000 milers so I put in a set of Comp Cams lifters. The noise decreased but did not go away. The only thing that fixed it was the Lucas oil additive. Considering the engine is supposed to run on 10-30 and is essentially brand new, this is wrong. Oil pressure at 800 rpm idle was 40 psi hot, now it is 50 psi hot. I know it is not an exhaust leak (I built my own headers and tracked down and welded up all the pinholes) or rocker problem because I have the pedestal rockers that are not prone to this problem. I almost think the lifter bores are machined oversized ...
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jul 15, 2005
#17
  • Jul 15, 2005
  • #17
Just make sure it's your lifters you hear....and not your injectors. Made that mistake before.
68 MGB
#18
  • Jul 16, 2005
  • #18
Good advice to check injectors, but in my case it is lifter noise because I have a carb on the engine.
JimBowy
330
Downriver, Mi
Jun 8, 2006
#19
  • Jun 8, 2006
  • #19
now how can you really verify if its exhaust, injectors, rockers, or lifters causing the ticking....
MustangGT92
89
Oklahoma City
Jun 8, 2006
#20
  • Jun 8, 2006
  • #20
i would say check the push rods and make sure they're not bent...i had one bend and thought it was my lifter.... so i changed my cam, lifters and push rods...
1 of 2 Next Last
R
Unidentified Ticking Noise
  • revised
  • Jul 5, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jul 11, 2026
MT94GT
9
Unknown engine tick
  • 94 Daily
  • Oct 31, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 1, 2025
91AOD5.0LX
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
