How do I make a block roller
  • Thread starter Thread starter WFOranger
  • Start date Start date Jan 19, 2007
W
WFOranger
28
  • Jan 19, 2007
I have a late model 351 block, and big surprise it is flat tappet. My question is how can I make it roller without buying those expensive bar link roller lifters. Is there anyway I can use the roller webbing from a 5.0 roller. And is it worth the effort. Any information you can give me would be helpful. Also I don't make much money so any help on making power for less cash would help. Thanks
seijirou
2,417
DFW
Jan 19, 2007
  • Jan 19, 2007
known ways that work is to use a reduced base circle cam, stock 5.0 hyd roller lifters, and the webbing from the roller block.
Something I think will work but I havn't had the chance to test it yet, is use solid roller lifters and not hydraulic ones. The solid ones don't use oil to stay pumped up, so it's okay that they come out of the lifter bore a little, I think.
I'm going to give it a shot, if you care to try before I do, let me know how it goes.
G
getusummm
156
  • Jan 19, 2007
Not all 351 roller blocks came with roller lifters. You really need to check the block date of manufacture. The solid lifters will work, but require many other things like springs, pushrods, etc, etc made for a solid cam
seijirou
2,417
DFW
Jan 22, 2007
  • Jan 22, 2007
Pushrods will probably need to be different. Depends on if solid roller lifters are a different length than hydraulic flat lifters. The cam and springs can stay the same.
C
Flat tappet to roller lifters--older block
  • chazmanaz
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 27, 2026
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
