How do I....
  • Thread starter Thread starter 93lxvb
  • Start date Start date May 16, 2006
9
93lxvb
  • May 16, 2006
I need to remove the AC and heat vents that are top, center on the dash (the double set. Want to install a guage cage.. How do I get the factory vents out??
88stangmangt
2,332
Stafford,VA
May 16, 2006
  • May 16, 2006
i would assume they are just held in by push clips.... some one will chime in....
bill302
2,131
alabama,gadsden
May 16, 2006
  • May 16, 2006
yes they are held in by push clips you can use a small screwdriver and carefully pry at sides outward and they will pop out doing it this way you take a small chance of breaking them if your not careful. another way to remove is to remove the whole dash console, its simple, you remove the panel at the bottom containing the shifter and boot it just pops out pry carefull at the top corners and pull it out far enough to expose the two bolts located under shifter and boot panel remove those two bolts and cigarette liter wires then you will remove the two rubber bumpers and two screws in the storage compartment under the radio look closely at the topside of this compartment you will see the screws remove these and the panel containing the vents will pop out then push on the backside of the vents they will come out...goodluck....and also a repair manual will tell you all this info.... there a good investment....
red9FOX3snake
PA
May 17, 2006
  • May 17, 2006
why not just carefully pull the vents from the original cage by getting a flat screw driver and carefully working each end out then with both vents out grab onto the center of the vent cage and pull, if it's still stubborn while pulling on the center section lift up on the 8 tabs that hold it into the dash... hope this helps
sunil6784
620
Boston, MA
May 17, 2006
  • May 17, 2006
I've just pryed them out gently on the sides. Done it a few times without any problems.
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
Interior and Upholstery 1993 Instrument Cluster cover
  • KevinV
  • Jul 2, 2026
Fox 5.0 Mustang Tech Jul 3, 2026
AeroCoupe
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
