How do different company x-pipes differ in sound? Aren't they really all the same when you think about it? I mean they are all steel in a form of an x. How are the different sounds created?
saleen195 said:How do different company x-pipes differ in sound? Aren't they really all the same when you think about it? I mean they are all steel in a form of an x. How are the different sounds created?![]()
Due to differences in exhaust flow & perfromance from 1 bank of your engine to your other, a crossover from one exhaust pipe to the other acutally helps performance. Sometimes one port pushes out less exhaust gases than the other port & a crossover really early in the flow helps even things out, increasing performance.CottonBurnerz said:come to think of it. Why do they even make H pipes X pipes and all those other pipes? Why don't they just have the pipes separated instead of joining together? Any purpose in this? Wound't the car run smoother without anything crossing between the flow?![]()
Correct. Basically all an H-pipe does is connect 2 otherwise parallel pipes perpendicularly. An x-pipe actually does a way better job of angling the 2 otherwise parallel pipes to a junction, increasing flow & performance.CottonBurnerz said:So the idea is to balance the amount of exhaust coming out.. now I can imagine how X-pipe can perform better than H..
Thanks a bunch![]()
hognutz said:then there is the covented "O" pipe. with 100% backpressure it really brings out the hp.
I remember that.. good times man
I thought about ordering 1 of thoseCottonBurnerz said:I remember that.. good times man
& putting it on the back of a V6 single exhaust Stang.CottonBurnerz said:Eh.. if that's the case. Then why did ford use H pipe set up instead of X pipe? Does it have something to do with gas mileage or something else?![]()
