how do you know when to rebuild??
  • Thread starter Thread starter 6FIVE_STANG
  • Start date Start date Jan 15, 2007
6FIVE_STANG
142
San Jose, CA
Jan 15, 2007
  • Jan 15, 2007
when i first bought my car ( 1 year ago ) the thing would burn rubber from a complete stop! now it takes off like an old cadilac. i thinking its my tranny and considering to get it rebuilt but how do i know if thats my problem?
note: its a C-4 but i usually manually shift and hardly never keep it in drive....thats another reason i think its my tranny.
302 coupe
1,952
Macon, Ga.
Jan 15, 2007
  • Jan 15, 2007
manually shifting will not hurt a transmission. You probably just need a good tune up.
rbohm
6,698
550
204
tucson,az
Jan 15, 2007
  • Jan 15, 2007
start with the basics. check the compression pressure, condition of the plugs and points, ignition timing, carb settings, etc. if this doesnt help, then check the slack in the timing chain. then adjust the bands in the trans if needed. you might also change the modulator valve in the trans as well.
A67StangMaster
401
San Jose CA
Jan 15, 2007
  • Jan 15, 2007
When you start smoking out the other end thats a good time to rebuild.. but it sounds like you just need a tune up..
krash kendall
1,258
Aldergrove, B.C. Canada
Jan 15, 2007
  • Jan 15, 2007
It could be something as simple as a vacuum leak - tune up will fix that.
6FIVE_STANG
142
San Jose, CA
Jan 16, 2007
  • Jan 16, 2007
- now that you mention that,..when i use to start my car its was very rare to see smoke , but now everytime i start my car white smoke comes out from the exhaust. what does this mean.?..
- ( MY MAIN CONCERN IS WHY DOES IT SEEM LIKE I HAVE NO TORQUE WHEN I TAKE OFF FROM A STOP?)
A67StangMaster
401
San Jose CA
Jan 16, 2007
  • Jan 16, 2007
do u still see smoke when your car is warmed up?
throw some 100 octain into everything should be new agian...lol
6FIVE_STANG
142
San Jose, CA
Jan 16, 2007
  • Jan 16, 2007
no smoke when warmed up,...just when i first start it.
- what are some clues showing that the tranny needs some attention?
302 coupe
1,952
Macon, Ga.
Jan 16, 2007
  • Jan 16, 2007
slipping, slow to shift, etc. If it were the trans causing your problem, the engine would rev free but you wouldn't be going anywhere. It wouldn't just bog the engine and take off slow. Its sounds like your problem is more in the tune of the engine. White smoke on startup is nothing to worry about, its just condensation.
6FIVE_STANG
142
San Jose, CA
Jan 16, 2007
#10
  • Jan 16, 2007
  • #10
what the average cost of a good tune-up? (etimation) just so i can have an idea...
69 Rustang
307
Orange County California
Jan 16, 2007
#11
  • Jan 16, 2007
  • #11
Smoking when first started is usually just bad valve stem seals. The symptom is a quick puff of blue that disappates within a minute or even seconds of starting. Smoking when revved up is a sign of more wear such as rings and bore wear. The typical signs for a rebuild for me are: 1) knocking 2) excessive sludge buildup affecting oil pressure or top end lubrication, 3) low compression/poor leakdown performance, and 4) excessive oil usage (approximately more than 1 qt per 1000 miles).
From what you described I am with many of the other opinions of tuneup and maintenance items needed.
68RCodeConv
345
Houston, TX
Jan 16, 2007
#12
  • Jan 16, 2007
  • #12
You might have a ruptured vacuum modulator which would allow tranny fluid to sucked into the intake. The VM is attached to the tranny and has a vacuum line running to the intake somewhere.
69 Rustang
307
Jan 16, 2007
#13
  • Jan 16, 2007
  • #13
68RCodeConv said:
You might have a ruptured vacuum modulator which would allow tranny fluid to sucked into the intake.QUOTE]
I have had that happen on two Mustangs previously and from my experience that is not a likely scenario for what he described. With both my cars, the car drove and shifted fairly normally, what was not normal was the blinding white James Bond smoke screen my cars left in their wake. In one car I was actually pulled over by the Nebraska State Hwy Patrol and the officer greeted me with "What in the He_ _ is wrong with this thing and why is it on my roads?!?!?!".
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 6:40 PM
AlexM556
A
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
