powershifting , helpful hint on how to do it right , old school style , when you start to take off in first , do this , grab the shifter while you have the pedal floored , if you have a decent clutch it shouldnt come out of gear as long as you are HARD on the throttle , pull back like you are trying to rip it out of the floor , when you get the revs about 200 to 500 rpms from where you wanna shift , stomp on the clutch pedal has hard and as fast as you can without letting off the gas , keep the gas DOWN , snap the clutch in and out bam bam , dont hesitate with it or you will MISS , your pulling back will pull it into second without even thinking about it , if none of you have been doing this try it tomorrow and let me know how it works for you , some people can do it some cant , seems to be a thing that just comes to you . Do third gear the same way but be very very careful , if you arent sure about your skills dont do it , ive seen to many people that thought they could drive a car slam one back into first , done it myself when i was mad at my girl , isnt good on the car , just push up and over to third while you are accelerating thru second gear , same process , 200 to 500 rpms shy of shift point , BAM in and out with the clutch pedal as fast as you can smack it down with your foot let off , some people side step it sometimes called , they kick it down and slide their foot off the left side of the pedal to make it even quicker , dont do this until you got the basics down of proper power shifting , alot of the older guys wont tell the younger guys how to do this properly because it does give you an edge if the other guy granny shifts or just shifts fast . do fourth the same way , hopefully by then you are smoking the other guy . and DONT LET OFF THE GAS
Good luck
