  • SN95 4.6L Mustang Tech
How do you put on Control Arms
  • Thread starter Thread starter sliver02GT
  • Start date Start date Sep 19, 2004
sliver02GT
84
  • Sep 19, 2004
Just like it says, how do you put a set of upper and lower control arms on,
is there a step by step write up out there on how to put these on
thanks
tomustang
Psychotic Member
3,434
McLean Hospital
Sep 20, 2004
  • Sep 20, 2004
go out and buy a set of spring compressors (lowering the control arms so the springs can depress is dangerous) and a chilton/haynes manual. two jack stands and a jack.
M
millatime
370
Palm Harbor, FL
Sep 20, 2004
  • Sep 20, 2004
you won't need spring compressors...when you lower the spring/shock assembly the spring will be fully relaxed to the point where you can remove it. Your best bet is to buy a haynes manual and follow that.
JonJon
4,801
back in Marylands
Sep 20, 2004
  • Sep 20, 2004
We just lowered the control arm slowly and eventually it was loose enough that the spring just came out. It was a very simple process to replace the stock arms and all I did was ask questions here.
Basically jack it up, support it, remove rim, jack up the LCA, unbolt 1 end of the LCA, lower it slowly, remove spring, disconnect other end of LCA, put in new one, put spring in, jack it back up, bolt it all together. Tah dah.
Uppers, I didn't do...
Wayne S
471
Warwick RI
Sep 20, 2004
  • Sep 20, 2004
Dont tighting all bolts till car is seating back on the ground under its own weight.
JonJon
4,801
back in Marylands
Sep 20, 2004
  • Sep 20, 2004
Good point.
M
millatime
370
Palm Harbor, FL
Sep 20, 2004
  • Sep 20, 2004
or on ramps in the rear so that you can actually crawl under there and tighten the bolts
Blev
1,295
So. Cal. V-Town
Sep 20, 2004
  • Sep 20, 2004
I was about to ask how the heII you're supposed to get under there and tighten it up.
Str8Pimp'n
492
Str8 outta Compton...
Sep 20, 2004
  • Sep 20, 2004
Here is a site that has some good info, the page here is an article on how to replace the LCA's
http://www.fordmuscle.com/archives/2000/03/controlarms/index.shtml
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
H
QA1 coilovers rubbing/hitting control arms
  • hassler
  • Sep 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
hassler
H
C
Shifter lever arm issue
  • chris1993
  • Jan 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Rcdgl
R
