How Do You Remove The Remove Rear Hub
slick68
11
ive have previously removed the front hub ,but can not remove the rears. Are they different then the front? there isnt even a grease cap, i would appreciate any help.
If you a talking about a rear hub, there isn't one. What are you trying to remove? The rear wheel bearing? What are you working on?
slick68 said:
im attemting to put new brakes shoes on, so i need to take off the rear drum. And it refuses to budge
I know it is a stereotypical thing to say, but it truly applies here, get a bigger hammer.
Get a nice rubber mallet and beat the tar out of the sides of the drum to help break it free.
The center of the drum is a very tight fit on the end of the axle. Take a pry bar or a big flat head screwdriver and pry on one side while you hit the other. There's not a whole lot to tear up so use as much force as you can stand.
It may help to stop by the parts store and get some penetrating oil to loosen the rust. Let it sit for awhile, then pull on the drum while tapping the outside edge with the hammer.
All you guys who want to wail on the poor brakes drums have something to learn about self-adjusters. Be SURE the shoes are free of the drums BEFORE you start beating on them. Drums CAN be damaged by excessive force!
you can release the rear shoes by turning the star adjuster wheel downward, while using another screwdriver to push the locking plate away from the adjuster wheel. Make sure your parking brake is not 'on'. If it is, your drums aint going nowhere.
ok these brakes have not been touched in prolly 10 years they are covered in rust and crud, so its hard to see much. where is this star adjuster? Is it on the front or rear of the drum?
there is a slot at the bottom of the backing plate on the backside of the drum, you can get a small screwdriver in there and use it to push the star wheel on the adjuster.
well i've got a pic of it from the 68 ford manual, but i cant figure out how to upload it....it wont let me delete my other pics....damn the man! email me if you want it.
I classic case of why everyone here who ever turns a wrench needs the FORD service manual. You can get new reprints of them for abou $20, a little more than a Haynes or Chiltons but worth every penny.
Hey! Is there an echo in here? :D See Timeless Wisdom #7. Actually, the reprints are more expensive than that. See your vendor catalogs.
Get a can of PB BLASTER (it WORKS) and spray on lugs and hub area first. This will help break lose any rust that may be in the area. Look on the bottom of the backing plate (under the axle housing) and you will see a small oval slot that SHOULD have a rubber plug in it. Pull the plug and then adjust the star wheel until you can turn the wheel by hand then see if the drum will come off. Repeat until drum slides off. You might also want to tap (Not beat on) the face of the drum with a deadblow hammer in the hub area to help loosen rust that might be between the drum and axle.
Sounds like you might have some badly worn drums with a ridge that is keeping the drums from coming off.
Make SURE you replace the rubber plug in the backing plate when you are done with the brake job.
Sorry if this sounds condescending but you wouldn't believe what I've seen folks do to the drum and backing plate trying to remove drums. :nonono:
Hope this helps.
Paul
Hope this helps.
Paul[/QUOTe
your right about the brakes, they have been used to the point where there is no pad left at all. Im sure the shoes have dug into the the drum, when i hit the brakes a loud metal on metal sound starts. THANKS for all the good tips guys, im gonna guy try this again
