How Do You Remove thses parts!?!
  • Thread starter Thread starter hemi_fan
  • Start date Start date Aug 3, 2004
hemi_fan
279
Ontario, Canada
Aug 3, 2004
  • Aug 3, 2004
Im takin off the front bumper, side skirts, spoiler, rear-bumper, headlights, and eventually the right front fender. Its on a GT obviously, but I have no clue how half this stuff is held on, or what sequence or part removal i need to follow (especially for the front end). Can anyone please tell me the locations of where these parts are held on, and what i need to do to get them off?? PLEASE!!
hemi_fan
279
Ontario, Canada
Aug 3, 2004
  • Aug 3, 2004
Oh yeah, and HOW IN THE HELL do you get the 2nd bolt out for the headlight assembly??? Its backed right up against sumthin so u cant get a socket on it... Can u use a wrench and slide the headlight off as you loosen??
dvs bullet
326
Ontario, Canada
Aug 3, 2004
  • Aug 3, 2004
there are some bolts for the front end that are right at the nose where the hood latch is, then on either side where the fenders connect there are nuts on the inside. you can see those nuts if you crawl underneath the front end alook up in the inner fender wells, they are all hidden in there.the side skirts the tops are held on with a retaining clip that once the screws on the bottm are remove it just slides up and out of the track. I see you are in Canada are you in the hamilton area?
dvs bullet
326
Ontario, Canada
Aug 3, 2004
  • Aug 3, 2004
for the head lights there should be three if I am not mistaken, I used a wrench for mine
hemi_fan
279
Ontario, Canada
Aug 3, 2004
  • Aug 3, 2004
I am in the hamilton area actually. I live in Ancaster, u kno where that is?
1jmc2003
  • Aug 3, 2004
Help with removal
Don't forget about the nut that is next to the door which mounts the fender. Open the door sit on the inside of your car and look straight towards the front of the car in between the door gap and the fender. You'll see what i am talking about.
dvs bullet
326
Ontario, Canada
Aug 3, 2004
  • Aug 3, 2004
Ya I'm just off Fennel on the mountain
dastang2
2,020
tx
Aug 3, 2004
  • Aug 3, 2004
to get the little rivets off that hold the top end of the front bumper, get a drill bit and drill the hole out, then it pops off
hemi_fan
279
Ontario, Canada
Aug 3, 2004
  • Aug 3, 2004
thanks for the tips guys! How about the spoiler, how does that come off??
K
Kiknads
44
#10
  • Aug 3, 2004
  • #10
take off that plastic piece on the bottom of your hatch and you should see them
hemi_fan
279
Ontario, Canada
Aug 3, 2004
#11
  • Aug 3, 2004
  • #11
I removed that piece and only saw 2 bolts... i undid those and it was still stuck on there pretty good, any other thigs i overlooked!?
dastang2
2,020
tx
Aug 3, 2004
#12
  • Aug 3, 2004
  • #12
there are 4 bolt holding it. 2 on each side
hemi_fan
279
Ontario, Canada
Aug 3, 2004
#13
  • Aug 3, 2004
  • #13
that would explain it... thanx
hemi_fan
279
Ontario, Canada
Aug 4, 2004
#14
  • Aug 4, 2004
  • #14
How do you disconnect the 3rd brakelight wire in the spoiler?? is there a clip or do u hafta cut it?!?!
dvs bullet
326
Ontario, Canada
Aug 4, 2004
#15
  • Aug 4, 2004
  • #15
pull out the gromet for the hole that the wire goes through the hatch there is a disconnect after that
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
Engine Information that is Needed When You Post a "Car is not Running" or "Car is Running Poorly" Thread
  • AeroCoupe
  • Apr 28, 2025
2K
Fox 5.0 Mustang Tech May 4, 2025
Bullitt347
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
