How easy is it to install new shocks and springs
Hi All,
The title says it all really,
I want to install some new shocks and springs on my 03 GT vert and wanted to find out if any special tools (like spring compression tool) are needed or any tips on install?
any comments welcome.
Iam sure there is a ton of write ups on this and iam sure someone will post them for you lol..
But no, you dont need to spring compression tool. To get the top nut off the strut under the hood, you will need an air compressor. (if you dont have one that is) its a pretty easy install but for you 1st time, give yourself a good afternoon or so (5hours or so)
The rear springs and shocks are really easy. Its a few bolts, and drop the rear end, and give the rear spring a good Kick and should fall right out. :rlaugh:
PM me if you have some questions. I have done the swap like 1,209,438,440,505 times now lol..
the best advice i can give, be patient, and have 2 hydrolic jacks available. if you have 2 people it usualy makes a world of difference. as soon as you drop the rear end you should be able to fanagle them out by hand. the front ones if you happen to have a really long screwdriver flathead, it tends to do the trick . good luck if you already havent done so
Its pretty easy , just get a few buddys to help out. I only had one hydraulic jack and didnt ever use my compressor during the install. Took us a whole saturday afternoon but it was worth it. You will want to get an alignment as soon as you get done though otherwise your tires are gonna get eaten alive.
I disagree. You will want to wait 2 weeks to allow settling of the springs. Then align the car.
Is it necessary to have the air compressor? Can the job be done with just a torque wrench?
The air compressor drives an impact wrench. The impact wrench makes it really easy to remove the top nut on the front shock. If you just turn it with a regular wrench, the shock turns with it. The impact of the air rachet allows you to loosen the nut with only minimal turning of the shock. Without an air compressor and air rachet, you will have to get creative with a long flat blade screwdriver to remove the top nut.
If you don't want to dick with the top nut, you will have to remove the C&C plate. It's one or the other. Either way, the shock needs to drop to allow the A arm to lower to get the spring out.
Most of the How-To's online didn't point this part out.
You can just disconnect the front strut from the spindle and never even pop the hood of the car to install the springs. If you wana change the front struts too you don't HAVE to use an impact. I can't remember if the stock struts have a relief in the top but my KYBs do. You can put a wrench onto the relieved part of the strut and turn the nut with a wrench. Its always nice to have a friend help hold one of the wrenches but it isn't the end of the word if you have to do it all yourself.
While you are there you should think about replacing the sway bar bushings with some poly ones. My rubber ones were SHOT a long time ago.
Great feedback peeps :)
So to recap:
1) The strut can be removed without the use of and air driver but would be easier if one is used.
I don't own one so looks like I get to do it the hard way :rolleyes:
2) Can the strut be disconnected from the spindle instead?
I guess it would be a bit more difficult to re-align the strut and spindle back together do to the compression factors at least that is what I have seen on coil over set-ups on the UK cars that I owned and worked on when I lived there.
New questions:
1) At what point do you need bumpsteer kit when lowering?
I don't want to go too low only about 1' 1/2" inch.
2) At what point do you require adjustable CC plates?
thanks for your comments.
I removed the 2 lower bolts on the strut when I installed mine. However, you are replacing yours, so It may not matter.
