how hard is it to install springs?
  • Thread starter Thread starter mustangkid05
  • Start date Start date May 8, 2007
mustangkid05
199
  • May 8, 2007
looking to get some within the next month, but are they easy to install, i did the search but couldnt come up with an answer specifically, also what springs do you reccomend?. and in the future i want to get some dd bullits with some wide tires so will lowering affect that?:SNSign:
thanks alot
EPIK
796
LEFT COAST
May 8, 2007
  • May 8, 2007
Go with H&R super sports, because they have the best compromise between a low stance, & decent ride quality & handling. They lower 94-04 Stangs about 1.8 front & 1.6 rear. You need more than just the springs to do it right though. Caster/camber plates, & performance shocks & struts are also a must, or else you wont be able to get the right alignment & the stock shocks & struts will make it a bouncy ride.
As far as installing the springs, its not very hard if you have the right tools & know the basics about Mustangs already.
Tim2002GT
635
Tulsa, Oklahoma
May 8, 2007
  • May 8, 2007
If you are mechanically inclined at all, then they are pretty easy to install. If you follow the link, it shows exactly what to do. http://www.stangnet.com/tech/spring.html I would recommend having two jacks and 4 jackstands and a friend to help with lowering and raising the control arms.
I used the Ford Racing "C" springs and they gave me a full 1 1/2" drop at all four corners. They are pretty reasonable price wise too. I gave $140 shipped for mine from www.americanmuscle.com. As far as the tire clearance issue, I can't really help you with that. I run a 17 x 9 Cobra R with a 275/40/17 tire and there is plenty of room for more tire.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
May 8, 2007
  • May 8, 2007
i can do a set in about 1 hour with hand tools. i have eibach sportlines and i like the drop they give me.
what springs are you looking at?
EPIK
796
LEFT COAST
May 8, 2007
  • May 8, 2007
The Sportlines do give u a killer lookin drop, but I have heard too many bad things about them, thats why I went with the H&R's. I liked them, but the drop wasnt enough, thats why I eventually went with coilovers in front, & I'lll be doing the rear soon too.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
May 8, 2007
  • May 8, 2007
i want some coilovers.......but i need to finish my engine sometime in the next year!
EPIK
796
LEFT COAST
May 8, 2007
  • May 8, 2007
Theres not many 4 valve engine mods that give u a good bang for the buck besides the big stuff like blowers, heads, & cams, so i decided to do suspension 1st. Everytime I think Im done with my suspension setup, I find something else I need. Next up is subframes & rear coil overs. Then I want the torque arm setup. Then after that, Ill think about finally tryin to get my blower. But i do want the tubular k member & a arms too.
Im sorry, none of this has to do with springs anymore, but i figured your ??? was answered.
mustangkid05
199
  • May 8, 2007
^^ thanks for the info guys
EPIK
796
LEFT COAST
May 8, 2007
  • May 8, 2007
No prob....
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
May 8, 2007
#10
  • May 8, 2007
  • #10
On the topic...how hard is it to install LCAs while you're already putting in struts/shocks, springs, and CC plates at the same time?
I've already got the springs & CC plates, but the bar is kinda got me at a stand-still with money. It is costing a lot more (around $600 so far) than I thought it would to build this bar!
EPIK
796
LEFT COAST
May 8, 2007
#11
  • May 8, 2007
  • #11
Well since your LCA's will probably be disconnected from the axle anyway, it will only require removing the bolt connecting the LCA's to the chassis. Its a breeze, & I highly recommend changing to the MM lca's. Its probably been one of my best mods. The only thing that will be a pain is that the mufflers kinda get in the way of the bolts, so u will have to unbolt the Catback & let it hang down.
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
M
  • mnky99
  • Sep 5, 2025
mnky99
M
