how hard is this??
  • Thread starter Thread starter jimsstang91
  • Start date Start date Dec 25, 2005
jimsstang91
101
  • Dec 25, 2005
i want to change my rear axels to 5 lug. it looks very easy??
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
Dec 25, 2005
  • Dec 25, 2005
not hard at all.. pull the cover off.. pull your drums off.. take the 8mm bolt loose.. push the big pin it out.. pull the C clips off and pull the axles out.. inspect your seals and bearings.. if bad change it.. if not then dont worry about it.. stick the other axles in, throw the c clips in, put the pin in, stick the 8mm bolt in and throw the cover back on.. and of course whatever your doing with brakes
P
PRO50SC
1,012
Olney, Maryland
Dec 26, 2005
  • Dec 26, 2005
:Word: and fill the dif!!
04sleeper
2,674
14
89
Dallas, TX
Dec 26, 2005
  • Dec 26, 2005
And don't forget the great smelling Friction Modifier!
Yummy.
M
Rim suggestions
  • mason5.0
  • Sep 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
M
What changes need to be made to the brake system after swapping a V8 rear axel into a V6 1999
  • MARTYMAN
  • Jan 21, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 22, 2026
Mustang5L5
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
