How Long For P0420
  • Thread starter Thread starter Shannon Foster
  • Start date Start date Sep 24, 2012
Shannon Foster
Chelsea, AL
Sep 24, 2012
  • Sep 24, 2012
My check engine light came on yesterday, I took it to my work to check it and it was a p0420. I reset it unaware that ford will cover the catalytic converter up to 80,000 miles. The car is a 2005 Ford Mustang GT s197 4.6 liter with 79,895 miles. Because I reset it, will they still be able to find it and if not how long will it take for the code to come back on. The technician said that at 80,000.01 miles they will not warranty it. I did however take a picture of the code and the date as well as the mileage just in case. So how many cycles or mileage will the code turn back on.
Thanks Everyone!!
Admin Dude
Jan 4, 1985
43,338
21,530
234
Box behind Walmart
Sep 24, 2012
  • Sep 24, 2012
FordCustSrvc
Shannon Foster
Chelsea, AL
Sep 25, 2012
  • Sep 25, 2012
Went to ford this morning and they told me that there was no codes evident on my car. I showed them the picture of the code I pulled with an OBD II reader and they said unless they can get it to display there is nothing to do. I said so if I drive back this weekend to go home, which is a 200 mile round trip and I will exceed 80,000 miles, and the light comes back on there is nothing you can do. They said that is correct. The only thing they found was a pending misfire that may be approaching and that I should replace the Coil and Plug. But that they found nothing wrong with the exhaust system. I am just upset that since I came to them with a problem regarding the Cat before the warranty runs out, and they couldn't find anything and basically they said you better hope that the light comes back on before you go over 80,000 or ford will "wash their hands of it and having nothing to do with it". So I made sure they made a service record of the visit just as record that I was there and see what they will do. Did I mention it costs me $89.00 for them to tell me basically nothing I did not already know...
bigb427
128
Las Vegas, NV
Sep 25, 2012
  • Sep 25, 2012
1st thing you need to do is repair what ever caused the missfire. If it is a bad coil and spark plug replace them. A miss will cause the convertor to fail if left un-repaired and driven long enough, and guess what - anything that can cause a missfire that's not covered under warranty is going to cause your cat. convertor replacement to become an out of pocket expense to you if you show up at the dealer with a missfire code AND a code for a bad convertor.
After you get that taken car of, you are going to need a scan tool that will display OBDII on board readiness or monitor status. If you have that, then you will need a manual that explains the exact steps needed to perform an OBDII drive cycle. With these two things you will be able to get the PCM to run the catalyst monitor in the least amount of driven miles. Any way you look at it, it's going to take some driving to get the code P0420 to reset, unless the convertor has pretty much stopped working all together. Good luck.
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
  • Gulftown980x
  • Jul 29, 2026
squeak93
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Friday at 3:18 PM
2000xp8
