94Blue302GT said:I'm pretty sure my manual with 2.73's had an 8 and an 18 teeth gears. for 3.73, just change the 8 to a 6.
it all depends on if you have 2.73 or 3.08 gears in there right now. however, when i went to the ford dealership the other day, they said that they put the same speedo gears in anyways. i guess that would be why it seems my speedo was a little off. Now i have the speedo gears in, but not the actual 3.73's yet, so i'm WAY off. When it reads 30 i'm doin about 40. I also figured out beforehand that in third at 2 grand i'm doin 40 and in fourth at 1500 i'm doin the same.V-Viper said:Think this is on topic, I have a 94 5-Spd and am about to get 3.73 gears.
How much will my speedo be off? And what/where can I get the part to fix it. Worth the $$ for install and all? Thanks.
Black70Fastback said:wait... im not so sure you can change the drive on on automatic that easy. or can you? i never play with the autos.
rel3rd said:That's correct. On an automatic, the speedo "drive" gear is actually part of the output shaft and cannot be changed. A SpeedCal only works on a 5 speed, so you are kinda screwed...I think a chip is the only option, and not 100% sure if that even can do it...
