How much alignment typically needed w/Lakewood scattershield?
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
I know how to indicate the crank in relation to the tranmission hole, but my question is how much offset is usually needed? I know I can get the offset dowels in .007, .014, and .021, but I was curious as to what I can expect. Also, how is it even necessary if the factory doesnt do it and just about never has a problem? I'm sure hiting the recommended .005" alignment window is ideal, but jeez, the dowel holes and trans bolt holes have more slop than that.
I have a McLeod bellhousing BTW, but I'm sure its no different than a Lakewood.
I have never measured my Lakewood bell housing's run out. Guess after 12 years it was ok from the manufacturer...
But in reality I probably should have taken the time. Got lucky I suppose.
I will check it, but I cant help but wonder if the manufacturers recommend such tight tolerances in an effort to prevent warranty claims(like "Your bellhousing wrecked my trans"). .005" is a tremendously small window for anyone to accurately align such pieces of machinery. This is assuming all the holes in the Lakewood are machined that accurately also....
Anyone else like to share?
Lakewood or any hydroformed bellhousings almost always need to be adjusted via shims or drilled holes and welded washers. The ford pieces are usualy pretty acurate.
I've recently done a 351 with a Lakewood bellhousing and we used .014 offset dowels to get us to .006 runout for a TKO. If I recall, we simply bolted up the bellhousing with the stock dowels and took runout readings to determine which offset dowels were needed.
Yeah, .005 is a pretty small window but if you grabbed an input shaft on a Tremec trans and tried to wiggle it, it simply doesn't move. Try that with a toploader and you'll find some wiggle. The Ford manual has .014 as runout specs for a toploader. For a Tremec the trans needs to be dead accurate centered in the input bushing or else there's preload on the shaft and shifting can become difficult.
Some folks get lucky and don't have to do any of this stuff with swapping in a Tremec. :hail2: With my luck, I usually end up spending a week of evenings trying to get it right. :shrug:
I recently installed a Lakewood on my motor. (out of car) I needed the .007 dowels. I installed mine for a toploader and IIRC my manual called for .009. It took about an hour to do, but I don't think I'd like to do it installed in the car.
