How Much HP and what would 1/4 mile be
91StangLX
95
How much horsepower and what would the 1/4 mile time be using this combination?
Thanks
FRPP Sportsman 306 Short Block with Forged Pistons and Crank
GT40P Heads Ported and Polished with 1.90 x 1.60 Valves and a .550 lift Spring Kit
1.6 Proform Roller Rockers
Professional Products Typhoon Intake Manifold
Mac Cold Air Induction
STOCK CAMSHAFT
65mm TB
73mm MAS
24lb Injectors
Mac Shorty Headers, Mac Prochamber and Mac Cat back Exhaust
MSD 6AL Ignition with MSD Billet Distributer
MSD 9mm Racing Spark Plug Wires
Iridium Plugs
Mac Underdrive Pullies
Art Carr Street Terminator Transmission with a 2600 Stall convertor
FRPP 3:73 rear gears with 31 spline axles, an Eaton 8.8 Differential
Custom Burned Diablo computer chip
255LPH Fuel Pump
Adj Fuel regulater
Set the timing to 16 degrees advance and the fuel to 37 PSI
Eibach Drag 90/10 shocks, FRPP Progressive rate springs
Eibach upper and lower control arms
Sub Frame connectors
QA1 Tubular K Member
Fiberglass hood with 1.5in cowl
Race Weight with driver is 3120
Thanks
STOCK CAMSHAFT
65mm TB
73mm MAS
24lb Injectors
Iridium Plugs
255LPH Fuel Pump
Adj Fuel regulater
I'm going to guess...255-270rwhp...maybe a bit more...that stock cam isn't really killing you...the stock cam is actually pretty nice...its that lower intake and heads that get you...but you got those covered... :nice:
"Close to low 12's"...with that "race weight"...come back with some times :nice:
5spd GT said:
I'm going to guess...260-270rwhp...maybe a bit more...that stock cam isn't really killing you...the stock cam is actually pretty nice...its that lower intake and heads that get you...but you got those covered... :nice:
I just ordered this short block after my went to the grave... This short block comes with a ford factory stock cam shaft and was thinking of switching out my TFS stage 1 cam. I think I will keep the factory cam and give it a try. I will be assembling the motor and dynoing it this week and heading to the track on Saturday to test it out. I will let you know what my times and HP are.
