Expired Fs: 1991 Mustang Lx Hatchback 5.0 45,893 Original Miles Lots Of Upgrades
Excellent Condition Florida Car 1991 Ford Mustang LX with 45,893 original miles "As of April 29th 2014 the odometer reads 9,319.5 Miles, with one original owner that I bought from that I am aware of, Absolutely Zero Rust, White exterior all original with zero rust and a few minor dings. The car has never been in any accidents. VIN Number 1FACP41EXMF121010. The speedometer gauge combined with actual mile gauge quit at 36,574 miles. I replaced with a new overhauled gauge from Late Model Restoration 50Resto/ Late Model Restoration in 2007 when they offered remanufactured Speedometers with Odometers. Original White paint that is in excellent shape with normal rock chips on the front bumper with tan plastic showing through as shown in the photos, rear bumper black strip has some tan coloring showing through. The car has been sitting in storage due to my deployment overseas for the past 5 years and has been regularly started and fuel has been treated regularly with Sta-Bil fuel stabilizer treatment. New Interstate Batteries Battery has been installed in April 2014. Everything is stock on the car if not mentioned below. Pick up and Shipping instructions are at the bottom of the list below.
Immaculate GT Black Interior all original with center console armrest delete, Power Windows, Power Door locks, Power Driver seat, Cruise Control, Power Steering, Heating and an aftermarket CD Player not secured in the center console.
MSD Ignition box mounted and hidden under the drivers side seat
Auto Meter Water Temperature and Oil Pressure Ultra Lite II gauges on the A pillar.
New headlights from Late Model Restoration
New tail lights from Late Model Restoration
New turn signal lamps from Late Model Restoration
New Hood Rubber Bumpers, and adjustment Bumpers from Late Model Restoration
Repainted cowl and windshield wiper arms, and outside mirrors in flat black.
Air conditioning has been removed forward of the engine firewall. I don't have these parts as they were removed before I purchased the car.
Cobra 10th Anniversary anthractice 17x9" wheels with front Nitto NT tires in good condition and rear with Nitto Street Radial tires, that need to be replaced
http://www.latemodelrestoration.com...-93-Mustang-Anthracite-Anniversary-Wheel-17X9
Ford Racing Performance 93 Cobra complete 4 wheel brake upgrade with 5 lug conversion. This kit is no longer offered for sale. New larger power booster, master cylinder, 4 each rotors, front Cobra grey calipers and rear calipers, 28 spline rear 5 lug axles, new parking brake cables, front wheel bearings and hubs and brake proportioning valve. The brake system works flawlessly.
94 Cobra front lower control arms with better bushings and ball joints.
Hotchkis Upper and Lower Rear Control Arms
Stock sway bars front and rear
Ford Racing Upgraded 1996 Front Lower Control Arms
http://www.latemodelrestoration.com/item/M3075A/79-93-Mustang-Ford-Racing-Front-Lower-Control-Arms
Ford Racing Aluminum driveshaft 28 spline
http://www.latemodelrestoration.com/item/M4602G/79-95-Mustang-Ford-Racing-Aluminum-Driveshaft
Car was originally an A04 Automatic, but has been converted to a TKO500 Manual transmission brand new with a Ford Racing King Cobra clutch, Ford Racing bell housing, adjustable clutch cable quadrant and firewall adjustment, polyurethane transmission mount. Still has cruise control.
http://www.latemodelrestoration.com/item/LRS-TKO600A/79-95-Ford-Mustang-Tremec-5-Speed-Transmission
http://www.latemodelrestoration.com...Transmission-Pedal-Assembly-Kit-Mustang-79-93
Stock 8.8 Rearend and Limited Slip Differential with aluminum differential strengthening cover. I think from Mac performance.
Stock fuel system.
Stock forged bottom end 302 motor never been touched. Polyurethane motor mounts, and oil has been changed every 2500 miles.
Trick Flow Top End Track Heat cylinder head kit with everything installed in the link below. ARP cylinder head bolts and ARP stainless valve cover studs, and ARP stainless intake manifold bolts.
http://www.latemodelrestoration.com...-50L-Trick-Flow-Track-Heat-Top-End-Kit-Silver
MSD Coil, Ford Racing Performance 9mm spark plug blue wires with weather proof rubber boot, Stock Distributor with Dyna Mod ignition module on distributor and billet hold down bracket. NGK racing spark plugs.
http://www.latemodelrestoration.com/item/LRS-12252CK/86-93-Mustang-50L-Blue-Underhood-Resto-Kit
http://www.latemodelrestoration.com...-Mustang-50L-58L-Dyna-Mod-Tfi-Ignition-Module
Upgraded 24lb. fuel injectors "unsure of the brand" stock fuel rails, upgraded in tank fuel pump, aftermarket fuel pressure regulator and fuel pressure gauge mounted in the engine compartment.
BBK shorty headers ceramic coated, BBK 2.5" offroad H pipe for shorty headers, Flowmaster American Thunder Cat Back Aluminized Steel exhaust system.
http://www.latemodelrestoration.com...Mustang-Bbk-50L-Ceramic-Coated-Shorty-Headers
http://www.latemodelrestoration.com...ang-Bbk-25-Off-Road-H-Pipe-For-Shorty-Headers
http://www.latemodelrestoration.com...g-50L-Lx-Flowmaster-American-Thunder-Cat-Back
Fluidyne Aluminum 3 row radiator with Aluminum coolant overflow tank. Flex a lite Black Magic electric fan kit, new upper radiator black brackets from Late Model Restoration, Aftermarket Milodon water pump, and Ford racing blue radiator hoses. http://www.latemodelrestoration.com/item/FHP-2093MU/79-93-Fluidyne-Mustang-Aluminum-Radiator
http://www.latemodelrestoration.com/item/FLX-185/79-93-Ford-Mustang-50L-Flex-a-Lite-Electric-Fan-Kit
130 Amp Alternator kit from PA Performance, with Billet aluminum adjustment rod and polished aluminum billet bracket.
http://www.latemodelrestoration.com/item/PA-16196B1/87-93-Mustang-130-Amp-Alternator
Performance Products EGR plate polished 65mm and Performance Products 65mm throttle body polished and harmonic balancer.
http://www.latemodelrestoration.com...-50L-65Mm-Polished-Professional-Products-Egr-
http://www.latemodelrestoration.com/item/PP-69200/1986-93-Mustang-50L-65mm-Polished-Throttle-Body
C&L intake aluminum pipe with mass air meters for 24lb. injectors.
http://www.latemodelrestoration.com...-50L-76Mm-Aluminum-C-L-Mass-Air-Meter-Kit-For
K&N Air filter in stock air box
New Idle air control Motor.
Maximum motorsports front black powder coated strut brace that ties the strut towers to the firewall, Steel Maximum Motorsports rectangular subframe connectors powder coated black welded in with seat support braces.
http://www.latemodelrestoration.com...m-Motorsports-Chassis-Brace-Package-Black-efi
New remanufactured power steering rack and pinion, stock power steering pump with billet aluminum polished bracket.
Aluminum underdrive pulleys blue anodized for water pump and Performance Products harmonic balancer and pulley spacer, smog pump delete bracket and aluminum pulley.
http://www.latemodelrestoration.com...-Powerforce-Lightweight-Harmonic-Balancer-Kit
Tokico struts and shocks with stock springs.
Hotchkis upper and lower rear control arms.
Shorty Antenna, with aftermarket CD player not mounted in console "unsure of brand."
Stock windows are in excellent condition.
New arm rest pad black on drivers door panel
http://www.latemodelrestoration.com...-Black-Door-Armrest-Pad-Kit-For-Power-Windows
Upgraded door hinge repair kit not yet installed is probably in the glove box.
http://www.latemodelrestoration.com...-Mustang-Door-Hinge-Pin-And-Bushings-Set-Of-4
All work on the car was performed by me in my garage. No labor was required to pay to a shop to do any work.
Have all receipts for parts installed on the car.
Minor ding on roof of car from previous owners elbow while waxing the car, Air Conditioning has been removed forward of the engine firewall as mention ed above, Moulding on drivers side door window rubber scraper is loose with rust bubbles and needs to be replaced. Coolant leaks from the front side of the intake manifold gasket on the drivers side
Pick up and or Shipping:
Car is available for pick up or if the buyer is wanting to have it shipped at their cost. The car is located in
Horse Shoe, NC 28742
Price: $10,500
Here is the link to view the entire album photos of the car.
http://s172.photobucket.com/user/mightymouse8364/slideshow/Mustang
Coolant leak has been repaired as of February 2015. New rear tires have been installed. New drivers side window scraper/dew wiper moulding has been installed in January 2015. Car has been completely detailed as of December 2014.
The car is located in Largo Florida 33770
New price is $9K firm
