How much power am I looking at?
Jacked_Fpx
Ford Racing 351W block (2bolt mains) stroked up to a 408
Eagle Crank
Manley Rods
Ross Pistons
Roller Cam
1.6 Rockers
AFR185's
Kooks Longtubes with 3"X pipe to burns stainless ultralights
Trick flow lower and upper set up, cut and ported
Pro TB
42lb Injectors
full fuel setup (External pump ect)
Spec Twin disk
TKO 600 with viper output shaft
11:0:1 Compression
C&L maf
Plan on running 2 kits, first a 100 shot wet and then another 100 on top but direct port.
On motor with the right tune what am I looking at power wise?
Non-tuning issue - moved to 5.0 Talk.
What cam are you going to run? Custom? Off the shelf grind? With a 408, those AFR 185's are likely going to hold you back. I'd look into some 205's and a custom cam, personally.
