I own a 98 Mustang GT which is currently being built.My block is currently at the machine shop but should be back in the car and all together by next weekend.Im hoping to get 300 to 320 wheel horsepower with my mods.Let me know if this is a resonable estimate and what do you think is a possible time for the car at the track.Here are the run down of parts.
98 block bored 20over,eagle h beams, probe pistons,PI head swap,comp valve springs with comp xe270 cams,PI intake,Trick Flow plenum,FRPP 70 mm TB,BBK cold air intake,BBK underdrive pulleys,255lph fuel pump,FRPP 30lb injectors,Mac longtubes,Xpipe,race bullets,and a Diablo chip,3.73 gears also.
, but I may end up swaping out my auto for a 5-speed, and I feel better haveing a auto car with NOS than a 5-speed, so I'll stick with a blower, with either trans I'll be ok. Plus the power will be there on demand, every time I need it. Pro charger or a KB will be my blower choices, with the cams I have Comp recomends a centrifugal blower so I'll probally end up with a 2 core Pro Charger with moderate boost (8-11psi)
