87 Hatch 331 Stroker Pa C4 Auto
james wilson
031.webp 039.webp clean car paint and iterior are in really good shape.. 331 stroker with eagle crank eagle h beam rods srp light weight pistons all balanced.. block was zero decked. electric water pump.. eddelbrock performer rpm heads. comp cam.. hr 274 part number.. trick flow intake 70 mm throttle body 30lb injectors 80mm mass air .. nx nitrous plate between upper and lower intake new tried it once.. inch and three quarter long tube headers three inch x pipe with three inch bullets. pa c4 auto with pa torque converter 1200 for conveter alone. reverse manual valae body with trans brake hammer shifter trans cooler with fan.. all tubular k member and a arms. coil overs strange adjustable struts caster camber plates.. eaton posi unit with 373 gears strange 31 spline axels.. had car to the strip once with 150 shot it went 670 in the eigth at 112 spinning.. would like to get 12500.00 its a really good car can drive anywhere i drive it to a local cruise here in town a few times a year.. if you are interested just give me a call..1 606 305 6418..​
