I just recently assembled a new engne and haven't got a chance to install it and get it dyno tuned yet. How much RWHP/ RWTQ do you 5.0 experts think it will produce. Here it is:
Stock Block Honed 0.010"
Stock Fully Balanced Crank
Stock Fully Balanced Rods w/ARP Pro-Series Wave-Loc Bolts
TRW Forged Aluminum 11.5.1 Pistons
Jon Kaase 247cc Aluminum Heads (2.10 int./ 1.60 exh valves) (Flow 323 CFM int./ 213 CFM exh. @600 Lift according to Car Craft Magazine In March 2004)
Lunati Hydralic Roller Cam (242/ 252 Duration @0.050) (560/ 576 Lift) (110 Lobe Seperation)
Edelbrock Victor 5.0 Intake (4000-7500 RPM Range)
BBK 75mm Throttle Body
C&L 76mm MAF
24lb Injectors
255lph Fuel Pump
MSD 6AL Igniton (7000 RPM Rev Limiter)
BBK 1 5/8" Longtube Headers
BBK 2 1/2" O/R H Pipe
Flowmaster 2 Chamber Exhaust
93/110 VP Mix Fuel
I also have a Nitrous Express Single Nozzle Wet Nitrous System and plan on spraying a 250 shot occasionally. I case any of you guys were going to say anything I have allready upgraded the nozzle to the "SHO" one, and upgraded the stock -3an seloniod-to-nozzle line with a -4an one so its good up to 300 hp.
I would be happy with 325 RWHP (on motor) but I've seen people with smaller heads and cams then me making 350+ RWHP with there 302.
I'm also hoping to make at least 550 RWHP and 550 RWTQ with the 250 shot.
C&L 76mm MAF
24lb Injectors
255lph Fuel Pump
93/110 VP Mix Fuel
