Sbf High End Parts For Sale
304billet
315
I have the following for sale: all parts were brand new, used for 10 passes.
AFR 205 heads, # 1450, 58cc, port matched to a 1262 gasket, Ferrera competition plus 2.08 intake and 1.6 exhaust valves, Isky high endurance solid roller yellow springs good to .720 lift, 10 degree Isky titanium retainers, Isky 10 degree locks, Viton valve seals, bronze valve guides, massaged chambers and polished. Fresh from machine shop with 5 angle valve job, pressure tested and resurfaced.
AFR 205 heads, # 1450, for solid roller
Eagle 4340 forged crank 3.25 stroke, Eagle 4340 forged H-beam rods w/ARP 2000 rod bolts 5.4 length, 7 JE reverse dome pistons -26.5cc - all zero balanced - had all checked by machine shop - $1,500
http://www.racingjunk.com/Rotating-A...ish..030-.html
Victor EFI 8.2 deck intake, port matched to 1262 gasket -$550
Victor EFI intake 8.2 deck
Cam Motion custom billet solid roller cam, 670/.680 lift, 260/280 dur, 114LC - $250
Cam Motion custom solid roller blower cam
Isky Red Zone High Endurance solid roller lifters -part # 3972-RH - $500
Isky Red Zone Solid Roller Link-bar lifters
NOS original 1993 Cobra upper intake from my 1993 cobra - $400
Racetronix Delphi 75lb race matched low impedence injectors -$300
Delphi 75lb low impedence injectors
BBK 75mm TB - $200
Manton 4130 pushrod -$100
Cloyes Hex adjustable timing set - $50
NOS 90 shot nitrous kit - $120
Hooker Super Comp 1 3/4" primary with 3" collector LT headers for Ford 87-93 with stock K-member - $350 part # 6227HKR - used with AFR 205 heads
Hooker Super Comp 1 3/4" by 3" LT headers
BBK short 2 1/2" H-pipe - $100
Hughes Powerglide 2 speed - $5,000
Dedenbear SFI case
9310 steel gears 1.76 1st gear ratio
Billet 4340 input shaft
Hughes 8inch Pro 3 GM93 converter 4500 stall
Custom 33.5” seamless steel drive shaft with 1350 joints
B & M shifter
pics :http://www.racingjunk.com/Racing-Tra...d-1700-hp.html
Accel DFI Gen. 6 complete system - part #74030 with Accel variable injector controller and installation instructions - for track race cars only - $350
[email protected]
213-200-9400
